12-11-2012, 07:59 PM
#15316
LT
A solution for tiles that dont match perfect w 4" drain top...
*L.T.*
tandctile-dot-net
2nd generation tile installer
12-11-2012, 08:01 PM
#15317
LT
OK,better shot.My bad
*L.T.*
tandctile-dot-net
12-11-2012, 08:02 PM
#15318
LT
I wont post my typical 20 pics at once.Ill show yall later...
*L.T.*
tandctile-dot-net
12-11-2012, 08:17 PM
#15319
Senior Contributor
And as if on cue the new GS arrived tonight.
Paul 1
12-11-2012, 08:29 PM
#15320
Itile345
Thanks I did do a little reading on em. It says they have a 16 joint when used. Anyone know of something like that with a 1/32 joint for marble etc?
Jamey
12-11-2012, 09:20 PM
#15321
Making Cents of It All
The TLS strap is a 1/32"
12-11-2012, 09:33 PM
#15322
Originally Posted by TLS
Q. What is the achievable grout line using the Tuscan Leveling System?
A. The thickness of the strap is 1/32'' however, recommended industry standard for grout lines is no less than 1/16'' wide.
Most commercial spacers can be used with the our edge leveling system to achieve up to a 1/2'' thick grout line.
12-11-2012, 09:51 PM
#15323
LT
Sorry guys,no leveling systems on my progress pics.I am,however,using a TLS bucket for my water.Oh,wait a minute....TMS (the mallet system)hahahhaha....
But I do have a new Dewalt with a Zipper blade !lol
*L.T.*
tandctile-dot-net
12-11-2012, 10:09 PM
#15324
Brian,
Since when do you follow rules ?
12-11-2012, 10:29 PM
#15325
Not realistically going to get less than a 1/16" grout line using TLS, and I'm betting any of the other systems either.
I try to stay clean, but there is always a bit of thinset it seems that gets behind the strap. That plus the thickness of the strap, and I don't think I am able to push two tiles closer together than 1/16". At least not without making a big effort.
12-11-2012, 10:51 PM
#15326
SchluterUgrad
Bars, steel lattice and maybe some razor wire on top of your Greenskin holding area Paul? I got a couple rolls myself and based on $/box I better lock em up tighter too.
12-11-2012, 11:03 PM
#15327
Tile Contractor
Jamey, the TLS is actually 1/32". Their 1/16" is just a recommendation for minimum joint width based on industry standards for getting the grout down in there.
12-11-2012, 11:57 PM
#15328
Itile345
Yeah. I always used 1/16 spacers and no matter how hard I try the grout lines always manage to look like 1/8 when it's all said and done. I started using the tavy 1/32 and it looks much better and is now around a 1/16. On marble it's more accurate. Generally I just use round tooth picks. I would like to try that TLS and see how it goes. Seems a bit expensive though.
Jamey
12-12-2012, 07:15 AM
#15329
Senior Contributor
The fencing is to keep the Jack Russells in. We foster. There is also a ring of cement pads buried around the perimeter so they can't dig their way out.
Paul 1
12-12-2012, 08:15 AM
#15330
LT, what you doing with a new DeWalt? Didn't you just get a new TS-60??
Chad Wilde
Precision Tile
Huron, SD
