Unread 09-04-2023, 10:21 PM   #1
Snets
Professional Weekend Warrior
Snets's Avatar
2X4 Lumber
Have you guys run into this? I'm remodeling a bathroom and need to add a number of studs into existing walls for various reasons...I sorted through the lumber at HD which is very close to the job and found some nice, dry and straight 2X4's and then found that they are not consistent dimensions. They are 1-1/2" X 3-5/8"......What the heck?
Thankfully I bought a Makita cordless planer a few years ago...to shave existing studs, not new ones!
Unread 09-05-2023, 05:57 AM   #2
I've seen that a few times.
Dang metric system!!!
I don't know the cause of that, other than some mill with the fence on their saw set wrong.
Unread 09-05-2023, 08:01 AM   #3
Do they feel particularly heavy, John? Not uncommon to find lumber at homers that's green enough to grow if you bury an end in the ground. Those 3 5/8ths" pieces could be down to 3 1/2" in a few weeks in conditioned space.
Take'em home and put a meter on them and find the KD lumber reading in excess of 30 percent moisture content.
But Homer's is 9 miles away and my lumber yard is 35 miles away, so.......
Unread 09-05-2023, 06:05 PM   #4
Snets
Snets's Avatar
Some were heavy, some were light, did not correlate with the odd dimensions. I'm not buying any more and the ones I used are blocking for shower glass.
The good lumber yard is less than 10 miles so not too bad.
Unread 09-05-2023, 07:54 PM   #5
Buying lumber at the big box stores is like buying all your best tools at Harbor freight.
Unread 09-06-2023, 10:48 AM   #6
Way back when I was a carpenter instead of a tile guy studs were 3-5/8 x 1-5/8. Sometime in the seventies they downsized. Big mess. Doesn't help current problems I know.
Concrete Lumber.... Lazarus Professionals' Hangout 3 04-03-2014 06:37 PM
Ditra over lumber - why not? emsnyder Tile Forum/Advice Board 2 08-21-2009 11:13 AM
Treated Lumber ok if I let it dry first? pitrow Tile Forum/Advice Board 32 12-09-2008 02:48 PM
Who's right, the lumber guy or calculator? dmaceld Tile Forum/Advice Board 3 05-21-2007 11:48 PM
lumber? and Ditra Bellsfloors Professionals' Hangout 4 05-02-2006 09:26 PM
