Unread 10-22-2019, 12:17 PM   #1
Ernesto A
Kerdi shower pan weeping around drain
Hello,
I just completed a 24 hour shower test and have some water leakage around the drain. The leakage is around the whole drain approximately 1 inch. I used a foam kerdi pan and drain. I also used Schulter all set for the shower pan and place the membrane a month ago. Rest is the shower shows no weeping. Is it ok to continue tiling or do I need to replace or repair. Awaiting Schulter rep call back. Need some additional expert advise.
Ernest
Ernesto A is offline   Reply With Quote
Unread 10-22-2019, 12:50 PM   #2
Did the water level actually drop?
Unread 10-22-2019, 01:00 PM   #3
Ernesto A
No water drop at all.
Ernest
Unread 10-22-2019, 03:04 PM   #4
Then, I would be inclined to tile away. There is no pressure on the pan under usage...unlike a flood test. Having said that, you could certainly carefully cut out a circle just past the suspect area, patch it with Kerdi and thinset it carefully. There will be a slight ridge there, but only an issue if using very small floor tiles...If you do this, make sure there is at least a 2" overlap...
You could also affix the repair with Kerdi Fix and a short taping knife...
Unread 10-22-2019, 03:15 PM   #5
Lou_MA
I’ve occasionally had wicking to that extent (or more) during flood tests, even when I know I had good thinset coverage and there were no voids. If the water level hasn’t dropped, I consider it good and proceed to tiling.
Lou
Unread 10-22-2019, 04:01 PM   #6
Ernesto A
Just talked to the Schulter rep. he looked at my photos and gave me the same advise. Sure do appreciate all of your input. Thank you
Ernest
Unread 10-28-2019, 11:25 PM   #7
Ernesto A
Kerdi band problem
Sad but true. My kitten pooped in the shower pan. While cleaning I pulled up a corner of the the kerdi band. . Then without thinking I pulled the band off completely. What is left is fleece and thinset. I do have a roll of 10 inch kerdi band which I am planning on placing over the seam with 3 inch overlap on either side. Would this work?
Ernest
Unread 10-29-2019, 12:48 AM   #8
If you have 2" of overlap at every seam, then you're good to go.
What I don't understand is how a 10" wide piece of band only gives you 3" of overlap on each side. If it's a seam, what happened to the other 4"?
If the edges of two pieces are 4" apart, you don't want to use Kerdi band, but a piece of Kerdi there.
If you have a buildup of thinset where the Kerdi band came up, you'll want to gently take it off with a rub brick. An excess of mortar will be a place for water to wick through and possibly leak out of the enclosure. Be careful not to get into the membrane with the rub brick, though.
If it's really bad buildup, and you have 4" between the edges that you're covering, then I'd consider cutting away those areas and recovering it with a piece of Kerdi with 2" overlaps.
Unread 10-29-2019, 06:00 AM   #9
Ernest,
We've merged your two threads. Having all the history, questions, and answers from your project located in one place really helps us all and tends to reduce duplicate efforts.
If you'd like your thread renamed to more clearly reflect the scope of your project we can do that too.
Unread 10-29-2019, 06:41 AM   #10
Lou_MA
I think he means 3” beyond where the original 5” k-band was folded and lapped beyond the seam. So he’ll have 5” of band beyond the seam, and the first 2.5” of that will be built up over the remnants of the first layer.
Lou
Unread 10-29-2019, 10:44 AM   #11
Ernesto A
Kerdi
Yes, I can’t add. I going to cover the 5 inch Kerdi band with a 10 inch with 2 1/2 inch overlap. Thank you Kevin and Lou. Appreciate your advice.
Ernest
Weeping shower (for days) Scrummy09 Tile Forum/Advice Board 12 02-27-2017 09:36 AM
New shower floor grout lines are weeping djn Tile Forum/Advice Board 63 01-28-2016 10:25 AM
Kerdi shower without Kerdi drain stouff93 Tile Forum/Advice Board 13 08-12-2010 08:31 AM
Kerdi shower without Kerdi drain? GC Louisville Tile Forum/Advice Board 4 07-15-2009 06:53 AM
Kerdi drain near edge of shower and Noble ProSlope vs. Kerdi Tray vs. mud Hickory Tile Forum/Advice Board 8 12-07-2005 03:42 PM
