Unread 01-09-2012, 08:54 PM   #1
seatofpantstile
Sealing 1/2" copper pipe
First question of probably a few for my project.
I'm doing a basic mortar pan shower with backer board on the walls and am wondering how to seal up the 2 ....1/2" copper pipes that are going to coming through the backerboard and Kerdi.
Also what about when you drill a couple screws in to mount your wall mounted shower faucet?
Thanks Tim
Tim
seatofpantstile is offline   Reply With Quote
Unread 01-09-2012, 10:15 PM   #2
muskymike
muskymike's Avatar
Hi Tim, welcome! You can cut the holes tight on the pipe or make some out of Kerdi band then use Kerdi fix around it. As for the holes you can put a blob of silicone in the hole before you put the screws in.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 01-10-2012, 08:36 AM   #3
Hi Tim,
What do you mean by "wall mounted faucet"? Would that be a shower head or a hand held shower? If a hand held you'll use plastic screw anchors which won't leak. If a shower head or shower valve, the screws will be behind the wall board.
Unread 01-10-2012, 03:12 PM   #4
seatofpantstile
Thanks for the responses.
It a Elizabethan Classics ECETS12
# Wall Mount Exposed Shower Faucet with Handshower
# 1/2in IPS inlets
# 3 3/8 in Centers
# 17 1/2in Shower arm reach
# 54in Overall height
# includes handshower, cradle and optional wall bracket
# Hot and Cold porcelain lever handles
Tim
Unread 01-18-2012, 04:59 PM   #5
seatofpantstile
Plumbing Question
So thanks for the earlier advice but I have another.
Just wondering if you all have any advice on how I should support my pipes that are coming into the 2 brass nipples that connect to the Esctcheon then to the faucet. Is it just a 90 over top of a 2x4?
Tim
Unread 01-18-2012, 05:07 PM   #6
seatofpantstile
here's the faucet with the brass nipple and then Escutcheon.
It seems pretty heavy just to hang it's weight on the pipe alone.
Help please. Thanks
Tim
Unread 01-18-2012, 05:09 PM   #7
seatofpantstile
In the first pic it's the back of a bathtub in my other bath. Then the 2.... 1/2" inlets coming up. I had to shave the 2x6 to get it square for the backer board which is why it looks rough.
Tim
Unread 01-19-2012, 10:39 AM   #8
dhagin
There's all kinds of fancy pipe supports out there, pick a good'n. Make sure the 2x is screwed/nailed solidly to the studs and then anchor the pipe to the 2x. Might need additional 2x's depending on the location of the existing one. I'd also support the pipe running vertically up to the valve from the floor by screwing another 2x to the studs about half way up.
Based on your photo above, you'll also anchor the finished shower head riser pipe to the tile surface. That finish support will likely have a screw(s) that will go thru the tile into another chunk of 2x in the wall. So, figure out where this anchor will be and make sure there's some solid 2x in the wall to hit with those screws. A wider 2x will make for a bigger target, so I typically use 2x10 or 2x12 for that sort of thing.
dana
how to bend copper pipe lati_cz The Mud Box 17 03-14-2011 04:13 PM
Copper pipe remodel problem Pheday Tile Forum/Advice Board 30 05-18-2006 11:59 PM
copper pipe union? Plumbing question calitundra Tile Forum/Advice Board 15 02-14-2005 03:36 PM
copper pipe and cement jerseyjoe Tile Forum/Advice Board 12 01-30-2005 10:29 AM
Epoxy on Copper Pipe cx The Mud Box 22 03-08-2003 09:23 AM
