Unread 10-23-2009, 01:39 PM   #1
Bill Vincent
Tile Contractor
Bill Vincent's Avatar
Next Gen Durock
Has anyone heard about or tried out this next generation Durock? My understanding is it's supposed to be 1/2 the weight and just as strong as the original?
http://durocknextgen.com/about.html
Bill
Unread 10-23-2009, 02:03 PM   #2
tileguytodd
Official Felker Fanatic
tileguytodd's Avatar
I think more like 25% less weight and simple score n snap vs the Old bugger
Prob a 1/2 way between EZBOARD and the old durock kinda thing.
I was checking it out this morning and sent info on to shop owner....he liked the looks of it....we'll see about pricing
Unread 10-23-2009, 03:27 PM   #3
I saw it in Depot, don't ask why I was there. They pulled permabase and now they carry this stuff. I cuts easily seems strong. Its 7.40 a sheet permabase was the same but I don't understand is the local tile shop carries permabase for 13 a sheet and its 7 at depot how???? How can all the sheets in depot be seconds? Depot now carries Sheetrock brand drywall so I guess they ditched Permabase too. Cause USG makes the Durock.
Unread 10-23-2009, 03:55 PM   #4
irish tileguy in michigan
Tile Contractor -- S.E. Michigan
irish tileguy in michigan's Avatar
Bill, we've been useing it for about 6 months now and i find it great to work with, if we ever had to use a backerboard it was always Durock and now the Next Generation just makes it easier.
Rick, my Home Depot carries durock for just under $8 and my supplier carries it for $12 but i usually get it from my supplier cause at HD they stack it 5 and 6 pallets high and when you get a lower pallet the boards are all bowed and warped and thats a no no.
Steve
Maloney Tile and Marble
Farmington Hills & Livonia, Mi.
Laticrete Hydroban & Schluter Kerdi shower installs
Custom installation of Tile and stone
irish tileguy in michigan is offline   Reply With Quote
Unread 10-23-2009, 04:29 PM   #5
Bill Vincent
Tile Contractor
That's about the kind of prices I get here, too. HD and Lowes are about 3.00 a sheet cheaper than the Dal warehouse in town. They're half the driving distance, too-- definitely a no brainer.
Bill
Unread 10-23-2009, 04:33 PM   #6
tilejoe
tilejoe's Avatar
Rick,
Not everything at depot and lowes are 2nds. Think of the NATIONAL purchasing power behind 1 item. your local shop will buy one truck load of permabase, but depot will commit to 1000 trucks.
Joe Lenner
Infinite Ceramic & Stone
www.infiniteceramic.com
NTCA Pennsylvania State Rep
CTEF Certified Installer #769
Unread 10-23-2009, 05:27 PM   #7
tileguynky
I have tried the 2nd gen. I still think it is too dense. In the sense that when I shoot a screw into the board, it chips out with little pieces real bad. Real aggravating when putting board on the ceiling. The Perma base seems to come out as a powder and the 2nd gen comes out in pieces. The 2 gen is lighter, enough to notice when you pick it up. Local tile shops are at $13 and HD is $8. Lowes is in the middle at $10.
Unread 10-23-2009, 05:28 PM   #8
I think Joe hit it on the head as far as HD pricing goes.
Is there any technical data on the product? Must I go to the USG site and search for it?
Unread 10-23-2009, 05:57 PM   #9
Bill Vincent
Tile Contractor
I'm sure there is. I've been talking to a rep over at Gardenweb, and I've invited him a couple of times to join us over here.
http://ths.gardenweb.com/forums/load...586775.html?11
Bill
Unread 10-23-2009, 07:00 PM   #10
It is rigid, I threw a couple sheets in my truck ontop of some buckets and thought they would snap. Permabase is definetly way stronger. But I use http://www.contractorsdirect.com/Til...Scoring-Cutter one of these and score the Durock twice and snap it like drywall and use a knife to cut the mesh on the back and a rasp or knife to clean the sides up.
I was big on hardibacker but its impossible to cut unless you have shears which I do but then you need to set up sawhorses and run a cord and I'd rather just cut the Mesh type backers right on the ground and not worry about using a cord.
Unread 10-23-2009, 07:17 PM   #11
gueuzeman
Losing permabase from home depot? - not good. You can still get it at Dal labeled as Dal- board. How is the edge on this board compared to Permabase? And it goes so well with using permacolor grout.
gueuzeman is offline   Reply With Quote
Unread 10-23-2009, 07:20 PM   #12
Crestone Tile
Gonzo!
... and more importantly, how does it smell???
Matt
"Shut it down!"
Crestone Tile is offline   Reply With Quote
Unread 10-23-2009, 08:10 PM   #13
custombuilt
My home dept has never had permabase-- only hardi and wonderboard. I do like permabase 1/4 inch for floors though, light and easy to cut.
Only thing I have never liked about durarock is that the half inch sheets can be flexed, and then they are never the same again. Super soft-- is the 2nd generation like that?
Jason W.
Superior Construction
Quincy, IL
Unread 10-23-2009, 10:17 PM   #14
WFB
tile setter
I had the same problem the last time I used Durrock. I use mostly permabase and score and snap it. I couldn't get it a few jobs ago so I got durrock. It seemed so soft I thought my scorer was going to go all the way through it. Just seemed really soft and crumbly to me. Haven't found any distributors here that carry the Nexgen stuff.
Berje
Just because I talk slow doesn't mean I'm stupid.
WFB is offline   Reply With Quote
Unread 10-23-2009, 10:51 PM   #15
MNTileGuy
Central Texas Tile Guy
No permabase around here either...
My local HD recently marked durock down to $7.88 a sheet for 1/2". No one else can touch that around here. In fact, for some reason, hardi is the "standard" around here, but I prefer durock or wonderboard since those score and snap better.
I'm curious about the next gen stuff too though...
Brad Bressler
Bressler Tile and Stone
www.bresslertile.com
Durock Next Gen LAN1870 Professionals' Hangout 12 12-08-2008 08:04 PM
Gen Contractors liability and workmans comp. Tile_Master Professionals' Hangout 6 08-01-2007 09:44 AM
Durock.. duxsi Tile Forum/Advice Board 1 03-26-2007 06:44 AM
Durock ??? Sting19 Tile Forum/Advice Board 2 11-22-2006 08:56 AM
