Hello All,
I'm installing a Sterling vikrell shower base in a utility area and seeking the wisdom of you folks on installing the base and prepping for tile on the surrounding floor.
Pic-1 shows the levelled base (currently shimmed). The left edge of the base is on the floor. The front middle and right edge are about 5/8" off the floor. I need to level the base and I am planning on tiling the floor in this area. I am using 12" ceramic tiles for this utility room floor (about 150 sq ft). My questions:
1. Can I use a wet mud mix underneath the base to level this up? I once read somewhere a suggestion to put a piece of 4 mil plastic between the base and the mud to make possible future removal easier. Is that advisable?
2. As you can see, I currently have the shower drain stubbed high. What is the best way to determine where to cut this off and how ? I'm using one of those shower drains with the rubber gizmo that seats around the PVC pipe. I'm a little concerned about this cutting operation since it is basically a one-shot deal.
3. I'm wondering whether I can manage to use full 12" tiles to tile the floor in front of the shower. There are no smaller sizes in the tile I'm using so if I can't use full tiles, can anyone offer suggestions? The distance from the edge of the floor drain to the front of the shower base is 1 12" tile width. Can I screed thinset from the bottom edge of the floor drain to the bottom edge of the shower to even this area out (maintaing a slight slope to the floor drain) ? I'm really looking for suggestions here.
4. From what I've read here, I should use an isolation membrane in these areas. I'd like to ditra the whole floor but that's too expensive for my budget. I thought I saw a post on this forum somewhere with a stick-down membrane that I might be able to use. What/where is that stuff ? Would it work here ?
The rest of the floor in this room has cut-back residue that I've scraped off to a shadow and I'm planning on using something like Ultraflex-II for thinset.
Thanks a ton for your advice
Charlie
