Unread 10-28-2020, 07:21 PM   #31
Germaintile
Unsanded
I'm gonna go with the Unsanded grout from Laticrete
Mary
Germaintile is offline   Reply With Quote
Unread 11-02-2020, 11:46 AM   #32
Germaintile
Caulk
Can someone advise me about what to use to caulk the drop- in sink to the countertop and also to caulk the first row of backsplash tiles to the countertop?
Laticrete makes a Latex Acrylic caulking in matching color to grout.
Or---I can get a clear silicone caulk from my hardware store.
What do I need to know before choosing?
Is the Acrylic as protective?
Is it customary to use an acrylic caulk that matches the grout color, in my case a light gray grout. Rather than going clear. Not sure what is meant by Translucent caulking. If anyone knows.......Thanks.
Mary
Unread 11-04-2020, 08:19 AM   #33
I'd want to use a silicone caulk for the sink, Mary, it'll last longer, but the acrylic for the back splash will be fine, and is much easier to apply than the silicone.
Laticrete makes both types in color matches.
If you do use silicone be sure to use something like blue painters tape which will help ensure clean, straight joints without getting silicone everywhere. Check this line for some very helpful tips: https://www.johnbridge.com/vbulletin...ad.php?t=85634
Unread 11-04-2020, 08:11 PM   #34
Germaintile
Thank you for tips on Mortar and Grout
Thank you, Dan. This is all I will even need to know about
caulking and most appreciated.
Mary
Unread 11-04-2020, 11:06 PM   #35
For caulking the bottom row of the backsplash where it meets the laminate top...
Between the laminate’s rate of expansion & contraction, coupled with the fact that many tops are more secured in the front rather than the back...there is a lot of movement at this back joint. Latex caulk is much more likely to crack than 100% silicone. For me, I’d use 100% silicone every time in this situation.
Wainscote tiling over painted wall ??? dandking Tile Forum/Advice Board 3 03-18-2015 09:02 AM
Tiling over painted cinderblock wall GoJackets Tile Forum/Advice Board 3 04-10-2007 01:47 PM
Tiling over painted wall lefty32 Tile Forum/Advice Board 5 10-07-2006 07:51 PM
Tiling over a painted wall... Redhawk996 Professionals' Hangout 8 02-01-2004 09:10 AM
Tiling over a painted wall vascott1 Tile Forum/Advice Board 3 09-07-2002 02:53 PM
