Unread 04-10-2020, 02:29 PM   #1
CNM DESIGN
Tile + 1/2" OSB + 1/2 Foam Board + 1/2" Drywall Deflection
Hello Everyone, long time since my last project.
Tiling a room with porcelain and will be hanging a drywall ceiling underneath.
There will be 1/2" Pex Al Pex between the OSB and the Drywall surrounded by the foam board as a spacer.
Will this be OK or is it to close?
For joists that are Unknown wood, but in good condition, 9.25 inches tall, 2.5 inches wide, 16 inches on center, and 15 feet long between supports, the deflection calculated is 0.444 inches.
This translates to a deflection of L / 405.
Since the maximum deflection for tile is L / 360, and for natural stone is L / 720, your floor is rated for Ceramic tile, Congratulations!
2x10 floor joist will be sistered on both sides with 1/2" OSB.
Craig
20yr retired combat vet, 17yr Master Weaver with the Longaberger Co. Owner of Final Salute LLC.. Veterans Memorial Shell Casing Displays.
www.afinalsalute.com
CNM DESIGN is offline   Reply With Quote
Unread 04-10-2020, 04:22 PM   #2
The deflection calculator won't give you an accurate number if you sister 1/2" ODB to the sides of your joists. It won't be the same as a solid piece of lumber 2.5" thick. Typical OSB isn't designed to be installed that way.
Unread 04-10-2020, 08:38 PM   #3
Welcome back, Craig.
'Fraid you've lost me completely there. Maybe more hints?
What Jim said. I have no idea what you might actually achieve using that method, but I'm reasonably sure it won't do you much good at all, 'specially considering that none of your pieces of OSB would be longer than 8 feet. Don't think it would be worth any of the effort.
Heated Garage floor with 3" pink foam board, What is easiest subfloor plywood +hardi? rollandelliott Tile Forum/Advice Board 29 06-27-2014 06:38 AM
Transition from 1/2" Hardi to 1/2" drywall and the 1/16" difference?? Stainless169 Tile Forum/Advice Board 18 02-10-2014 08:32 PM
12x24 porcelain over 1/2" drywall "greenboard" Vojtech Tile Forum/Advice Board 3 06-21-2012 12:43 PM
1/4" cement board meets 1/2" drywall gorgiasred Tile Forum/Advice Board 29 02-06-2010 02:41 PM
Quick question "mud" with tile vs. drywall jthoni Tile Forum/Advice Board 1 06-07-2005 02:32 PM
