Unread 04-13-2015, 09:55 PM   #1
HomeDepotAssociate
HomeDepotAssociate's Avatar
12" & 11 7/8ths tile. Solution?
Curious, if you're doing a tile job (and maybe some of you have run in to this), and you have the misfortune of winding up with 12" tile and 11 7/8ths tile, is there a way to finish a job without having screwy grout lines? Can you plan for this if you know you have two different tile sizes? And is that the sign of a cheap tile/bad manufacturing? Just curious because I've run in to this a few times with customers, and I assume its just a matter of . . getting the same tile sizing. . But that's not always an option, like, if you're halfway through a job.
Thoughts?
Kontorsion
(Chate')
HomeDepotAssociate is offline   Reply With Quote
Unread 04-14-2015, 11:52 AM   #2
dhagin
It's common to find different sizes within a manufacturing run. Manufacturers typically box tiles with lot numbers on boxes, and sourcing tile from the same lot *may* help reduce getting different sizes. "Rectified" tiles are cut after manufacture, so are more uniform in size. Rectified tiles still need to be sorted by lot and checked, as described below.
But, we're not done yet!
Once the installer gets the boxes on the job, they need to open a representative number of boxes, pick out some tiles, and stack them up on edge side by side to compare sizes. After stacking and checking a few, rotate them and check sizes in the other direction. There is typically some difference in sizes.
The installer needs to come up with the differences in tile sizes to determine grout joint width. The **minimum** grout joint size = 3x the difference in tile sizes. For example, if the differences are slight, say 1/16", then the **minimum** grout joint size is 3/16".
There is typically some differences in tile sizes with manufactured tile. Planning for this is what makes the jobs come out looking just fine. Specifying grout joint width, before doing all the above is a recipe for disaster.
dana
Unread 04-14-2015, 04:29 PM   #3
cpad007
hack of some trades
cpad007's Avatar
Geeeez, Dana, I'd rather design rockets.
Chris
DIYer-us Extrem-us Non-Pro-us
Chris' Orange Tile Project
cpad007 is offline   Reply With Quote
Unread 04-16-2015, 12:52 PM   #4
HomeDepotAssociate
MEGA, mega helpful, thank you so uch
Kontorsion
(Chate')
Different tile thicknesses: 5-cent solution? GfromKC Tile Forum/Advice Board 18 03-10-2010 11:04 AM
Need a tile solution zubenelgenubi Tile Forum/Advice Board 3 06-14-2009 07:02 PM
What is the best solution to clean tile floors? Mrs.J Tile Forum/Advice Board 21 05-27-2005 10:02 PM
Old tile washed with vinegar solution... COBALT Tile Forum/Advice Board 6 11-03-2004 11:49 AM
regretful "multi-piece surround kit" owner seeks solution to shower failure Joe Kane Tile Forum/Advice Board 7 06-07-2004 05:54 AM
