Unread 03-17-2015, 06:54 PM   #1
dandking
Wainscote tiling over painted wall ???
I plan to extend my shower tile job with 12x18 inch porcelain tiles to wainscoat the wall behind the toilet and vanity. Can I tile over the fresh paint on the wall. Thinset is my plan. Backerboard is installed in the shower area and is flush with the rest of the painted wall.
Please advise.
Don
dandking is offline   Reply With Quote
Unread 03-17-2015, 07:09 PM   #2
Welcome, Don.
I'll guess your remaining walls are common drywall and say, yes, but first you need to at least rough up the paint with very coarse sandpaper. 36 or 50 grit vigorously applied should work well if you use a good quality polymer modified thinset mortar. Not my favorite installation substrate, but it seems to work all right in dry areas.
Unread 03-18-2015, 08:49 AM   #3
dandking
Actually, it is wet plaster painted with eggshell latex paint, Glidden.
Don
Unread 03-18-2015, 09:02 AM   #4
Keep in mind that you'll be bonding your tile to your paint. If your paint is not well bonded, your tile won't be, either.
When you initially install your tile to the latex-based paint with thinset mortar you'll soften the paint substantially and your bond will depend upon your waiting long enough for the mortar to cure and the paint to dry again.
Tiling over painted cinderblock wall GoJackets Tile Forum/Advice Board 3 04-10-2007 01:47 PM
Tiling over painted wall lefty32 Tile Forum/Advice Board 5 10-07-2006 07:51 PM
transition from wall tile to painted wall Hickory Tile Forum/Advice Board 3 04-04-2006 11:18 PM
Tiling over a painted wall... Redhawk996 Professionals' Hangout 8 02-01-2004 09:10 AM
Tiling over a painted wall vascott1 Tile Forum/Advice Board 3 09-07-2002 02:53 PM
