Unread 10-08-2020, 01:36 PM   #1
qwertyjjj
How to cut installed tile on floor
This is tile in an entrance way.
Unfortunately, the tiler did something weird whilst we were not watching and the tile is not lined up with the wall next to it. He instead took some sort of odd perspective measurement.
In any case, we didn't pay for this part and they refused to correct it so now I have to straighten out somehow.
Is there anyway to use a grinder with guide or circular saw to cut it straight?
Removing the silver trim is going to be difficult too.
Tile to correct
https://imgur.com/a/c2xrDUO
Gordon
qwertyjjj is offline   Reply With Quote
Unread 10-08-2020, 01:39 PM   #2
qwertyjjj
Tile https://imgur.com/a/h61wJlW
Gordon
Unread 10-08-2020, 02:39 PM   #3
Radas
Tile Newbie
It's hard to tell from the pictures but it appears the tile is not square to the entryway or the entryway wall is not square to the adjacent room containing the tile, is that correct?
If you decide to keep the tile in place, my suggestion is to use a diamond blade on a track saw to cut the tile square to the entryway. Alternatively, you can also use a compact masonry saw (dewalt makes one and I believe it allows for wet cutting) along with a guide to make the cut. I'd prefer the track saw because you can connect it to a dust collector for a clean cut.
I'd recommend testing either method with a scrap tile to make sure chipping won't be an issue before you cut your installed tile.
The easier method would be to rip up the few tiles that are proud of the entryway, clean off the old thinset, and set new tile cut the way you're expecting. Is there a reason why the installer won't do this?
Sent from my Pixel 3 using Tapatalk
Ali
..a new excuse to hoard tools
Unread 10-08-2020, 04:35 PM   #4
qwertyjjj
If I rip up a few tiles whole, is there anyway to re-use then and take the thinset off the bottom of the tile?
Gordon
Unread 10-08-2020, 05:14 PM   #5
It's possible, if they were not bonded correctly, that they could come up in one piece. Of course, that would bring another more serious problem to light.
I would plan on them not being usable and have some more on hand.
Cutting them in place with a grinder and diamond wheel is probably the best option, provided they don't chip on the edge.
Unread 10-08-2020, 07:00 PM   #6
qwertyjjj
Ok, and lastly where the tile meets the drywall, how do I finish the cut there? I could cut into the drywall by 2" but not ideal. Suppose I should cut a bit out first to see exactly what's behind
Gordon
Unread 10-08-2020, 07:24 PM   #7
Gordon, it'll help if you'll post your photos as attachments from storage on your computer so they appear in your post and remain a permanent part of your thread.
Unread 10-11-2020, 12:21 PM   #8
Tiger Mountain Tile Inc
I bought one of these for doing something similar. It'll chip up the edge of the tile and spit small chips out but it works with a straight edge.
Your best bet is to get it as close to the drywall as possible and maybe even cut some of the drywall so that it'll cut further. Then try scoring the remaining piece with something like this and try to break it downward.
Then sand or file the edge.
James Upton
Tired of bullnose tile trim? Here are 5 edge trim alternatives ~DIYTileGuy
Unread 10-11-2020, 07:36 PM   #9
Or you can buy a little 4” circular wet saw. It looks like a mini circular saw, but it’s outfitted with a diamond blade and a hose to gently supply a spray of water to make it easier to cut without crazy chipping. You’ll need to set up a straightedge, as suggested. And I’d have a second person helping to wet vac the water.
I like durable tools. Mostly, more expensive tools last a lot longer than their cheaper competitors, so they end up being cheaper in the long run. But if you only need or want a tool for limited use, cheaper tools might be okay. Here’s an inexpensive Ryobi 4” circular wet saw for $89. You can find more durable wet saws like this in the $150+ range.
I’m not able to view the pictures without downloading an app, so I don’t know what type of tile you’ve got. If it’s ceramic or porcelain, I’d suggest using a 1” diamond cutting wheel like these (about $15 at a home center that sells bits for Dremel/rotary-type tools) in a rotary tool to finish the cuts on either end.
How to cut installed floor tile? andy_m Tile Forum/Advice Board 12 07-27-2014 08:37 AM
Cutting Installed Floor Tile FreddieJ Tile Forum/Advice Board 4 02-16-2010 09:39 AM
Cutting Existing Installed Floor Tile KULTULZ Tile Forum/Advice Board 9 12-18-2007 03:26 AM
cutting installed floor tile whbunker Tile Forum/Advice Board 3 12-04-2005 04:23 PM
What to do after tile floor is installed floandpete Tile Forum/Advice Board 8 03-20-2004 08:44 PM
