Old 10-16-2018, 05:54 PM   #1
raisingcainp
leveling and honeing marble floor
delipped and flattened floor with 4" monster vacuum brazed 70 grit diamond. what step is next to achieve a honed low luster finish?
William
raisingcainp is offline   Reply With Quote
Old 10-17-2018, 12:55 AM   #2
Welcome to the forum, William.
While I could give you generic advice about using 4” wet diamond pads to polish the tiles up to your desired low-level, sheen, it would result in a wavy surface due to the small size of the pads relative to the floor. Polishing floors is typically done with multi-head polishing machine to avoid the very problem of waviness. The equipment is kinda pricey and I don’t have direct experience...so I can’t help you much.
But I can set the stage for someone who can by asking:
What marble are you working with? And what equipment are you intending to use?
Old 10-17-2018, 05:25 AM   #3
raisingcainp
it's a 100 square foot jack and JILL bath with a 4" by 12" run of herringbone pattern
William
Old 10-17-2018, 06:50 AM   #4
The pads I have go from 80 to 3000 grit. I believe the second grit is either 120 or 150. I've only used them to polish edges of marble when tiling showers so I don't have much experience polishing flat surfaces. Like Bubba said, keeping the marble flat would be my concern when using small pads. Maybe someone with more experience will drop in.
Old 10-17-2018, 02:01 PM   #5
Trask
Oregon Tile Man
Trask's Avatar
Hey William,
I would echo what was mentioned above ..
It’s a fairly involved task to get a marble floor flat
And evenly finished... I’ve spent most of my life in the industry working with stone ,
And would hardly consider myself qualified to grind a floor professionally .
You want a larger footprint abrasive pad and machine to keep the
“ fun house “ effect or wavy surface from happening . A 4” disk , even a rigid disk , will be almost impossible to run flat while eliminating even minor discrepancies/ lippange .
‘ off the record ‘ I’ve seen a few guys ( not in the stone trade) surprise me with their hand skill and raw determination . One wood floor guy I encountered
Used his floor sander with screen disks dry and worked it up from 80g to a hogs hair pad . The edging was likely tricky but he had lots of soft wood floor experience and ( aside from the awful dust ) it looked like he was doing a remarkably fine job considering he had zero stone experience.
Worth mentioning too ...
Stone should be grouted and WELL CURED ...as well as set correctly . If you start grinding with a heavy or aggressive machine you can easily comprise poorly set floors or lose / chip corners . Also Softer marbles are a double edged sword .. easy to grind and easy to grind a hole!
Trask Bergerson
Bergerson Tile and Stone
Astoria, Oregon
Old 10-17-2018, 02:13 PM   #6
Welcome back, Trask. Been a while.
Leveling System for Polished Marble kittonian Tile Forum/Advice Board 12 01-12-2018 04:37 PM
Leveling Marble Slab on Floor? BobTilecraft Professionals' Hangout 12 12-10-2012 01:15 AM
Marble Over Self Leveling Compound bergs4 Tile Forum/Advice Board 14 11-14-2008 08:26 AM
Removed marble Tile, Need help leveling surface! hnaegele Tile Forum/Advice Board 1 07-11-2005 05:52 AM
marble floor ...tar layer issue...leveling... elda Tile Forum/Advice Board 0 10-08-2004 02:01 PM
