Old 09-17-2018, 08:22 PM   #106
SemiDriven
Gettin' there! (side-tracked by life and other projects.)
Tacking the entryway and glass tile stripes in the coming weeks.
Question: I managed to put 2 pea-sized chips into 2 different tiles. I have the chips. What do you suggest I use to glue those suckers back into the tile?
Chris
SemiDriven is offline   Reply With Quote
Old 09-17-2018, 10:00 PM   #107
Lou_MA
Superglue. One that can be used on ceramics. Just a tiny spot of it so it doesn’t squeeze out and / or raise the chip higher than the surrounding tile.
Lou
Old 09-18-2018, 06:47 AM   #108
SemiDriven
Thanks for the tip Lou!
I'm gonna try Loctite's Ultra Gel Control Super Glue.
Chris
Old 09-18-2018, 07:18 AM   #109
Lou_MA
Lower viscosity is better. Gel can be thick. And be very careful with the edges of the chip, where it tapers off. They’re very fragile. If the chip doesn’t get seated fully flush with the tile, you may want to carefully push in some unsanded grout.
Lou
Old 09-18-2018, 09:21 PM   #110
SemiDriven
Got it. Thinner is better (low viscosity).
I was thinking about surrounding the chips with grout to help prevent further chipping. Your comments helped clarify how to do what I may need to do.
Thanks Lou!
Chris
Old 10-17-2018, 06:49 AM   #111
SemiDriven
Hey guys,
Just noticed that one of my 4'' X 1" glass tiles is loose. It's still attached but I can pivot it out of the wall a little. Will grout be enough to hold it in place or should I remove it entirely and then reattach it?
Chris
Old 10-17-2018, 07:23 AM   #112
Lou_MA
Remove it, carefully scrape down thinset, vac, and re-set
Lou
Old 10-17-2018, 08:59 PM   #113
SemiDriven
OK--thanks Lou!
What tool(s) do you usually use for such a procedure like this?
Chris
Old 10-18-2018, 05:07 AM   #114
Lou_MA
In most cases the moisture from the thinset has weakened the bond of the tile to the mesh backing. Take a small putty knife and pry out the loose mosaic and it should come out fairly easy. If you notice it’s still attached to the mesh and pulling up adjacent tiles, just carefully cut out the loose tile - without nicking the Kerdi - while still prying it out.
Start prying between the loose tile and another mosaic. Hopefully you won’t chip the tile you’re using as leverage, but if so, it’ll be easier to replace a second mosaic than a bigger field tile.
Then use the putty knife or whatever you have handy to scrape down the old thinset.
Lou
Old 10-18-2018, 05:16 AM   #115
Utility knife to cut the mesh to separate that tile from the rest( carefully as to not puncture the waterproofing) a wood chisel or a low grit sand paper to sand off the thinset (again being careful not to damage the waterproofing) the wood chisel take a steady hand at just the right angle.You don't need to hammer it, you can drag the wood chisel instead of driving it. A grout removal tool works good also.
Last edited by smifwal; 10-18-2018 at 05:18 AM. Reason: Lou has faster fingers than I do
Old 10-18-2018, 06:47 AM   #116
Gozo
As said above, but be REAL careful with removing the thinset from the Schluter membrane. The only thing it has to bind to are the fibers. If you scrape right down to the orange, you’re likely scraping off the fibers as well. Nothing (mortarwise) sticks well to the raw smooth plastic. I’d leave a thin layer of thinset remaining and then bond to that. Being such a small area, a modified mortar would probably be fine and give you some extra stickiness, just give it some time to start to cure before regrouting.
Old 10-18-2018, 09:13 PM   #117
SemiDriven
Great advice Lou! Wasn't a moisture issue in my case. While laying tile adjacent to that area, I managed to elbow the spacer dislodging the glass tile. Even after putting it back into place, the thinset was too far along to hold it firmly in place.
Chris
Old 10-18-2018, 09:16 PM   #118
SemiDriven
Utility knife and wood chisel: genius! Careful cutting and scraping did the trick. Pushing the wood chisel blade forward in shallow passes worked best for me. Thanks Shawn!
Chris
Old 10-18-2018, 09:18 PM   #119
SemiDriven
Got a few spots where I got down to the orange fiber. Overall, it is still mainly covered in a thin layer of thinset. I'm using Glass Tile Premium Thinset Mortar (Custom). It bonded well to the Kerdi. Haven't grouted yet so no worries! Thanks Jeff!
Chris
Old 11-15-2018, 07:45 AM   #120
SemiDriven
I'm a wee bit concerned that water getting behind the shower handle areas could start some mildew action over time. In other words, there's not a clear slope at the bottom for water to drain out back onto the tile. Should I build that out with thinset a bit?
Chris
Heidi's Master Bathroom 2BPS Tile Forum/Advice Board 264 07-26-2013 08:29 AM
Heidi's Guest Bathroom 2BPS Tile Forum/Advice Board 46 02-04-2013 12:24 AM
Chris's Shower Project ChrisMazzeo Tile Forum/Advice Board 11 11-11-2012 07:06 PM
Chris' Kerdi Shower cbrown1976 Tile Forum/Advice Board 95 07-21-2008 02:57 PM
Chris's Kerdi Shower CRMW Tile Forum/Advice Board 9 03-28-2005 11:51 AM
