Welcome, Mike.
Originally Posted by Mike
The slab is pretty much level across the crack so it doesn't appear to be heaving or sinking on either side.
Sorry, if there is
any vertical displacement between the sides of your crack, your chance for a successful ceramic tile installation is essentially nil. You can, of course, tile over it if you like, it being your house and your tile and your dinero and all, but I'd recommend you at least look into alternate floor coverings.
As far as patching the crack, I'm not sure what your purpose would be there, but one of the Quikrete products at Homer's would likely work fine. Even it it requires more than one application, you're only talking about an hour or so between'em. But again, I wonder at the purpose.
You do understand that you'll not be making the slab whole again, right? The crack is still there, it's just filled up some.
I assume that since the house is 40 years old, the slab is not likely to move or shift any further.
While I, on the other hand, without even knowing your geographic location (would help if you'd enter that into your User Profile), would assume that the slab is likely to move at least twice a year.
