Unread 11-17-2003, 10:11 AM   #1
pelon
Guest
Posts: n/a
stone fireplace
Does anyone out there have info on installing "Cultured Stone". I am building a fireplace with hearth ect.. and using that manufactured stone. Do you use cbu or the old wire lath and scratch coat?? Thanks, Pete
Unread 11-17-2003, 10:14 AM   #2
Sonnie Layne
Da Poet
far as I know, you can use either. I've only used one brand.
da' poet
Sonnie Layne is offline   Reply With Quote
Unread 11-17-2003, 02:24 PM   #3
Hello Pete. Welcome aboard.
I've seen it done over metal lath, and I've seen it done over concrete, too. If you can install the lath easily, that's what I would do. They usually give it a thin scratch coat and then install the "stone" with additional mortar.
