Unread 04-04-2006, 03:05 PM   #1
MRB
HELP - Running bond with 10x13
Hi all, this is my first post to this great resouce.
I've just done our en-suite room and will be tiling it at the weekend. Managment has taken a shine to having the new tiles in a brick (running bond) pattern.
The room is 6ft x 5ft and the tiles are 10"x13". I have never tiled in this way before and therefore would like some advice on the starting point, what happens at corners etc. and what happens around the window 4ft x 2ft window which is right in the middle of one wall and is recessed by about 4"'s.
Do I start at one end and continue around the room as I believe I can't start from the middle because I don't think it will look right.
Your help would be greatly appreciated.
Mark
MRB is offline   Reply With Quote
Unread 04-04-2006, 03:15 PM   #2
JTG
JTG's Avatar
Mark
This is going to be walls or floor? Sounder like walls.
I would try and start in the middle of the wall across from the door and bring everything back to the wall.
With a running bond pattern how the tile come out is how they come out as you will either have a full or half tile starting from the mid point. At the two inside corners save the cut pieces and use them as continuation on other wall.
Good luck
JTG
Jerry
Santa Seattle
Ballard
Unread 04-05-2006, 02:01 AM   #3
MRB
JTG
Thanks for your reply.
I take it I'll have to check a couple of courses to try and make sure I'm left with a decent amount of tile at each end? And by using the off cut on the adjacent wall this gives the illusion of a full tile.
Regards Mark.
Unread 04-05-2006, 05:22 AM   #4
Autoplay
Tile Setter
As JTG said.....the cut is what it is. With Runningbond,there's no real shifting of the layout. And as JTG stated,start in the middle. 1 row of tile will be what it is,the other row of tile will be what it is.
Rich
12x12 running bond Denver Chuck Tile Forum/Advice Board 26 09-09-2012 02:10 PM
control joint in running bond just1more Tile Forum/Advice Board 12 02-13-2009 10:19 PM
running bond on diagonal kevjob Professionals' Hangout 10 03-02-2006 07:02 AM
Newbie layout - running bond pcono Tile Forum/Advice Board 3 12-07-2005 11:26 AM
Layout of Running Bond Tile Robert Villa Professionals' Hangout 8 10-09-2002 07:08 AM
