Unread 11-28-2016, 02:49 PM   #121
wkumtrider
Thanks Ryan and CX! I guess I need to make a decision.
Jason
wkumtrider is offline   Reply With Quote
Unread 12-29-2016, 07:05 AM   #122
wkumtrider
Grout question: I have a bag of grout that needs to be mixed. Is it ok to mix a little at a time or should I mix the entire bag at once so the color will be consistent? I'm afraid if I mix the entire bag it will dry before I can use it. I know I will be slow and take my time applying the grout. Thanks!
Jason
Unread 12-29-2016, 07:56 AM   #123
Dry mix the powder to be consistent. Then use as much powder as you want.
Have you read the grouting tutorial some nice guy wrote?
Unread 12-29-2016, 09:19 PM   #124
wkumtrider
Thanks Houston. I'll check out the tutorial.
Jason
Unread 12-30-2016, 08:09 AM   #125
Its your lucky day !
We have a caulking tutorial for when you're finished grouting.
Unread 12-30-2016, 09:15 AM   #126
wkumtrider
Houston, should I dump the entire bag in a bucket and dry mix it, then use another bucket to mix what I need?
Jason
Unread 12-30-2016, 09:49 AM   #127
Good plan, that.
Unread 12-30-2016, 09:33 PM   #128
wkumtrider
Just wanted to let everyone know I completed grouting tonight. Looks good. Thanks for all the help and advice!
Jason
Unread 12-30-2016, 09:44 PM   #129
Pictures or it doesn't count.
Unread 12-31-2016, 01:31 PM   #130
wkumtrider
Still have some cleaning up to do and the grout needs to set for at least 24 hrs, but it is done.
Jason
Unread 05-06-2017, 10:29 AM   #131
wkumtrider
Shower Door Recommendation
Anyone have a recommendation for a nice shower door? I need one that is adjustable because my opening is not perfectly plumb (about 1/4" difference). My opening is right at 30". I looked at all the big box stores but haven't really seen anything I like. Not sure what the pros use or recommend.
Jason
Unread 05-06-2017, 12:37 PM   #132
I found it best to let a glass company handle that part of the project. The cost of the doors are not that much until you get into the frameless doors, and considering they do the installation for you, I couldn't find that I'd save much at all by buying one and installing it myself, particularly if a wall is out of plumb. They have expander jambs to take care of that problem.
Unread 05-09-2017, 01:50 PM   #133
wkumtrider
Thanks Kman. I do plan to have someone install the shower door.
Jason
Jason's Steam Shower overourheads_SF Tile Forum/Advice Board 11 07-01-2010 05:11 PM
Jason's Kirdy shower Bing Tile Forum/Advice Board 31 10-11-2009 07:06 PM
Jason's excellent shower project jcasteel Tile Forum/Advice Board 19 09-20-2009 09:04 AM
Help!...Demolish/Rebuild Small 35-yr-old Bathroom sinkholed Tile Forum/Advice Board 54 08-04-2007 09:14 AM
