Unread 04-15-2009, 01:00 PM   #1
StoneFireplace
stone mason
resin backed stone tile
What's the rules here? Thank you for your time.
StoneFireplace is offline   Reply With Quote
Unread 04-15-2009, 01:27 PM   #2
Can you be a little more specific? Are you asking about setting materials or....???
Unread 04-15-2009, 01:31 PM   #3
StoneFireplace
stone mason
Lately I am seeing more and more stone tiles with a resin on the back. Everyone says not to use thin-set;even modified. I have been told to use epoxy, but I have never used it. I also heard you could put something on the backs to "back-butter" the stone and then use thin-set. What do you think?
Unread 04-15-2009, 01:44 PM   #4
Certain moisture sensitive stones (green colored stones are a big red flag) known as serpentine are prone to curling from the moisture in thinset. They begin to warp and pull away from the thinset before it's established a solid bond. In these cases, setting them with epoxy...or coating the backs of them with epoxy, then setting them after they've cured with modified thinset is common.
If the resin backing on the tile is smooth, Tec (Brand) wants you to use an epoxy to set. But if the backing is real rough, they'll let you use a high dollar modified. Like most of the stuff we do, it changes with manufacturers and have to look into unfamiliar tiles.
Unread 04-16-2009, 02:57 AM   #5
StoneFireplace
stone mason
Thank you very much for your help.
resin backed marble tiles Soup2Nuts Tile Forum/Advice Board 36 11-29-2007 11:35 AM
Resin-backed Marble raghavac Tile Forum/Advice Board 2 01-01-2005 08:17 PM
