Removing shluter all set mortar from textured tile
Hi,
I have been reading a lot of helpful posts on this forum and was unable to find one specific to exact situation, so I thought I'd ask and see if any experts can help me.
I had a kitchen floor Tile installed by a tiler recommended by a contractor friend, it's a grey textured porcelain tile 12 x 24
, that was installed over ditra heat with schluter all set mortar. I specifically asked this guy prior to installation if he required sealers etc as I was providing all material so it was at no extra cost to him. Anyway, tile was installed, then grouted days after, the paper was put down covering entire floor while other stuff was going on. When I lift the paper coming close to end of project, there was bad grout haze and a LOT of small spots and smears of thinset on face of tile. The paper was put down by someone else before I could take a look. This was around 2 weeks ago, so I spent several hours yesterday cleaning with Grout haze remover, then rinsing thoroughly with water and drying each section as I went, this removed the vast majority of the Grout haze and some of the thinset, but some spots remain and it'd very noticeably on grey tile. What should be the next step I should try, or should it be a case of replacing the affected tile, I don't trust the guy to not cut through the ditra heat so it will be something I may just tackle myself if need be with a mylar sheet to show the lines.
Thanks in advance for any advice.
Ray
