Take a look at these directions from
AcrylPro.
The very first limitation to the product listed is at the top of the page:
Limitations to the Product
Recommended floor tile size: 8" (20 cm) or less on all sides.
So, while the wet mastic (I can say for centainty that the mastic was not dried within 1 day) indeed plays games with the color of the grout (and is also a common complaint with inexpensive grouts such as this), the point is kind of over-ridden by the fundamental mistake of using this product incorrectly. I'm very sorry to tell you that the product is not likely to dry anytime soon. Such a mistake is fixed by replacing the products with a setting material that is approved for such an installation. When paying a professional to install this, they are expected to a a workman like job and not use inappropriate materials like this. I would demand a replacement of the tile, setting material, and substrate to correct said mistake.
P.S. It also appears from the photo that they may have neglected to leave a 1/4" gap between the tile and the wall board.
