Unread 08-04-2008, 06:13 AM   #1
rambo1224
Remove dried thin-set from tile
I had tiled a large bathroom wall and some of the thin-set dried on the tiles (used a modified thin-set). What is the best way to remove the dried thin-set. I started with a sponge/water but its not working very well.
rambo1224 is offline   Reply With Quote
Unread 08-04-2008, 06:26 AM   #2
Try some vinegar. Soak a rag in it and use it to keep the thinset wet. Scrub with a stiff synthetic bristle brush. Try to keep the vinegar out from behind the tiles.
Unread 08-04-2008, 06:28 AM   #3
tileman2000
New England Tile Man
tileman2000's Avatar
How long has the thinset been on the tile?How about wetting it and using a razor scraper.....That should do the trick.
What Bob said will work also.
Michael
Unread 08-04-2008, 06:58 AM   #4
matman
Tile contractor
An angle grinder fitted with a standard diamond dry blade laid over on its side grinds it off pretty easily, but very dusty.
Matt
matman is offline   Reply With Quote
Unread 08-04-2008, 04:56 PM   #5
Matt,
I think you missed it was on the tile.
I wouldn't trust using a grinder on the finished tile. one slip and you need to now replace a tile.
I would just use a 5 in 1 Painters Tool or a flat head screw driver and scratch it off.
check on a piece of tile first and make sure the metal tool doesn't leave metal marks on the tile.
