Hi Keith and welcome aboard,
The Plasplug saw you have cuts from underneath the material, correct? This means that the blade is "breaking"' through the glaze instead of cutting through it. Sometimes this can be minimized by flipping the tile upside-down and placing the glazed side on the table surface? Also, buying a tile dressing stone will allow you to clean up your cut edges a bit more. You can find a dressing stone amoung the other tile tools at any home improvement store and it should be under $10. The chipping out might be taken care of by flipping the tile but you should make sure that the table is rinsed clear of debris before every cut also. It sometimes helps prevent chipping out by applying equal and even pressure to both sides of a cut as it goes through the blade. Since the chipping is caused by a build up of tension released through the weakest portion of the material, providing counter-pressure can work on some materials. Chipping out is also common in tile which is "cupped" or out-of-plane as this can focus the above mentioned tension instead of allowing it to distribute through the entire material. Flipping the tile can reduce this effect also.
Best of luck,
Shaughnn.
