Wellcome, Bill.
It all sounds fine to me. Injineer Bob gits a little twitchy when you talk about cantilevers and deflection standards on accounta it gets a little complicated. But I think he's gonna give you a green tag on all your sturcture.
As for additional plywood, it appears from my first reading that you have sistered joists everywhere on 16" spacing. The minimum standard for CBU over OSB is generally 3/4 inch over 16" on center spacing. That allows a 14 1/2 inch span for the subflooring. Keep in mind that's the
minimum. You are spanning only 13 inches, so you're above the minimums for ceramic tile. We don't like to see people using the minimum required subflooring, and usually recommend they add some plywood. You are clearly not a guy who accepts the minimum on your framing, so I'm gonna leave it up to you.
My biggest question is the "Permabase." I'm not at all familiar with that product. I trust you have read their specs or contacted them for their recommendations on installation?
