Unread 11-05-2010, 05:56 PM   #1
C.R.L Construction
string as spacer
Does or has anyone ever used string or rope as a spacing for tile. An old tiler i used to work with would use it and i was wondering what would be the best type to use. Worth a try i think.
Chris
C.R.L Construction is offline   Reply With Quote
Unread 11-05-2010, 05:59 PM   #2
ob1kanobee
ob1kanobee's Avatar
Why would you want to do this?
Other reasons to use a string but for tile spacing? Maybe you misunderstood him.
Ben
Rule number one in life: You go with what you got, imperfections and all.
ob1kanobee is offline   Reply With Quote
Unread 11-05-2010, 06:03 PM   #3
C.R.L Construction
Ive seen him use it. Its like a 1/4" rope that he would use and it would compress enough to give you a nice 1/8 joint and it would keep the joints clean for grouting. he said he learnt that from an old italian setter when he was much younger
Chris
Unread 11-05-2010, 06:08 PM   #4
Chris,
That very technique was discussed at the JB mud course. Many old timers had seen it.
Unread 11-05-2010, 06:41 PM   #5
MudMaker
The Revolution has begun/Make America Great Again
MudMaker's Avatar
Used a white cotton string but only for 4x4's inna shower.. Also used tile boxes cut up into squares...
mm (aka "Paco")
MudMaker is offline   Reply With Quote
Unread 11-05-2010, 06:43 PM   #6
Davestone
Florida Tile & Stone Man
I heard of it many times years ago, and tried it on circular tub decks,and circular showers.Never worked good for me.Plain old nylon wound 1/4" as said.
http://Davestonestile.com
Unread 11-05-2010, 06:44 PM   #7
Davestone
I've built a lotta mud curbs with tile boxes.
Unread 11-05-2010, 07:07 PM   #8
Hey! Some of us younger guys were familiar with the method, too.
And it'll still work, Chris, but I find spacers and wedges to be much more convenient.
Which relates to using string as a spacer just how, Stoner?
You got a link?
Unread 11-05-2010, 07:20 PM   #9
same here.
I used it, also used sized rope many times on quarry tile walls and
a good amount of 12x12 walls.
you need a soft rope or string and put it in a bucket of water so it absorbs the water.
as you set your rows you lay the damp rope in the horizontal joint and then stack on that.
after a day the water evaporates from the rope and pulls out of the grout joints easily.
Tampa Florida Tile Installation
^^Check out our Blog^^
Unread 11-05-2010, 07:55 PM   #10
ob1kanobee
ob1kanobee's Avatar
I'm with CX. I would use spacers. Plenty of other uses for rope. If spacers weren't available like inna old days then I'm sure rope was just fine.
Ben
Unread 11-05-2010, 08:29 PM   #11
Toddman
Independent Tile Contractor
Toddman's Avatar
I've heard old timers talk about the string/rope also. I don't get it myself. Seems to me that would only work if the tile are all consistently sized, which is rarely the case. Shims and spacers for this guy.
Todd
Good work is not cheap, and cheap work is not good.
http://www.toddthetileguy.com
Toddman is offline   Reply With Quote
Unread 11-05-2010, 08:33 PM   #12
Scottish Tile and Stone
Ohio Tile Contractor.. Hydroban shower specialist
Scottish Tile and Stone's Avatar
almost all of the older homes around here that are plaster walls, have tile set with string
Scott.
www.scottishtileandstone.com
Laticrete hydroban showers
Mud set stone.
ditra kerdi stone showers waterproof mudset stone backsplashes glass tiles,laticrete, hydroban,ohio,cleveland,painesville,backsplashes,
Scottish Tile and Stone is offline   Reply With Quote
Unread 11-05-2010, 08:53 PM   #13
Levi the Tile Guy
Tile and Stone Contractor
Levi the Tile Guy's Avatar
And they just left the string in the grout joint?
Levi The Tile Guy
Grand Junction, Colorado Tile and Stone installation
Levi the Tile Guy is offline   Reply With Quote
Unread 11-05-2010, 09:24 PM   #14
Chris, using something that will compress will give you troubles, that's one of the problems with a rope. Many old timers would use a fine string that wouldn't compress much. The problem is, because of the weight, the higher you stack the wall up the more the rope compresses on the lower section and less on the top. That makes the joints smaller on the lower part of the wall. I seldom ever use spacers these days, nearly all wedges.
Unread 11-05-2010, 09:32 PM   #15
Levi.. They sure did. Every job Ive torn out, had the string still in there..
Scott.
Mud set stone.
String Mop? My wife hates it! Now what? Cashflow Cleaning, Restoration and Sealing 8 06-08-2009 09:10 PM
42 String Guitar dgunnels The Mud Box 7 07-02-2008 05:50 AM
Product String a level? MUDDY Professionals' Hangout 14 11-04-2007 05:07 PM
Silly String ziggy96 Tile Forum/Advice Board 6 04-30-2006 10:48 AM
