Unread 12-30-2020, 07:31 PM   #1
SilverBullet07
Threshold question
I am replacing some tile that was installed 32 years ago. Whoever installed it stopped the tile right at the yellow line in the picture below. When I tile a room I like to take it to the red line in the photo.
I was planning to pull back the carpet and extend the plywood further into the threshold and lay the tile to the red line.
Is my thinking correct or am I being to annal?
Harold
SilverBullet07 is offline   Reply With Quote
Unread 12-30-2020, 07:51 PM   #2
PC7060
PC7060's Avatar
You are right on Harold! You have two options for the width of the threshold.
1. Cut your threshold to width to hit the red line to marked to the yellow line you marked edge of the wall. That will give you a clean edge for your floor tile termination.
2. Or cut a narrow threshold the thickness of the door and bring your tile into the doorway. (my preferred approach)
Unread 12-30-2020, 11:15 PM   #3
Where does the door close, on the yellow line or to the left of the red line? Why do you need a threshold? Your tile is supposed to fall in the middle of where the door shuts so when you close the door you see tile from one side and tile from the other.
Unread 12-31-2020, 05:41 AM   #4
SilverBullet07
Door opens and shuts on the yellow line side and stops at the blue line. No I don’t need a threshold just wondering how far to bring the tiles into the doorway.
Should I stop just where the door stops on the blue line or between the blue and red line which is the middle?
Harold
Unread 12-31-2020, 07:04 AM   #5
PC7060
PC7060's Avatar
Sorry, based on your thread title, I assumed you wanted to put in a threshold.
As smifwal said, typically (best practice), the transition occurs under the door. We can’t see if this is hinged or pocket door so only you know where that line is.
Unread 12-31-2020, 07:30 AM   #6
SilverBullet07
Thanks, Yes the door is hinge and stops at the blue line. So i will tile to it.
Harold
Unread 12-31-2020, 09:11 AM   #7
PC7060
PC7060's Avatar
Sounds like good plan. Don’t forget to undercut door jamb on the side so you can slips tiles under frame.
Unread 12-31-2020, 11:43 AM   #8
. I measure from the stop to the edge of the jamb and split the difference. So that would be in the middle of the yellow and blue line.
Threshold question JeanneMarie Tile Forum/Advice Board 3 09-21-2016 02:33 PM
Threshold Question dansal Tile Forum/Advice Board 38 11-11-2010 09:20 AM
Threshold Question bdoon Tile Forum/Advice Board 2 04-24-2005 06:13 AM
Another Threshold Question MightyShadow Tile Forum/Advice Board 7 03-21-2005 08:44 PM
Threshold question...help grace48 Tile Forum/Advice Board 1 03-18-2005 08:52 AM
