Unread 01-12-2012, 12:17 PM   #1
Jay_bee
Questions about doing a curbless shower
Hey guys, I have a handicap shower that I am going to be doing. My question is what to do where the hot mop over laps the sub floor. The pan is recessed and hot mopped and the hot mop runs over the sub floor about six inches and is about 3/8 thick. I am going to float the pan. I will be using 1/2 hardi on the floor. So where the hardi buts to the hot mop it will be almost the same height.
Thanks in advance.
Justin
Jay_bee is offline   Reply With Quote
Unread 01-12-2012, 04:38 PM   #2
That method wouldn't have been my first choice!
Depending on the size of the shower and the placement of the showerhead, how would you waterproof the area outside of the shower if overspray got there? CBU isn't waterproof, just stable in water.
the setting bed needs thickness, so that adds to the top of the hotmop, which will be quite a bit more than that 1/2". Maybe some pictures would help, then the pros can cogitate a reasonable answer for you.
Unread 01-13-2012, 11:15 PM   #3
Jay_bee
The pan is 3'x4' and is 2" lower than the sub floor so there will be 2" of deck mud to bring it up to the same hieght as the floor tile. I will get some pics but I won't be back till next week.
What would be your preferred method?
Justin
Unread 01-14-2012, 09:36 AM   #4
You can salvage your plan by waterproofing the top of the CBU and marrying that waterproofing into the hot mop. Not sure how you'd accomplish that.
My preferred method would have been to use a surface membrane for the entire project such as kerdi, noble, or hydroban. That way you can shape the shower floor to the exact height then waterproof the shower and main bath floor all with the same product line. In the pic below we tiled the HC shower for an injured US Marine. The shower was in Kerdi with the floor in Ditra, the kerdi overlapped to the ditra, waterproofing the entire bathroom floor.
Unread 01-14-2012, 10:17 AM   #5
Justin,
if your already hot mopped and putting mud over it and then Hardi on the floor that isnt a good way to do a curbless shower.
you are going to need to have the waterproofing on top of the Hardi and it has to run continuous onto the top of the mud bed.
I think you should look into HydroBan on the top and a way to tie the liquid membrane into the drain with a divot.
curbless shower (or almost curbless) Apt4C Tile Forum/Advice Board 656 03-08-2011 09:58 PM
on to the repair of the defective curbless shower. Many questions... Chris99 Tile Forum/Advice Board 50 01-13-2010 09:08 PM
Curbless Walk-In Shower Questions kirkw12 Tile Forum/Advice Board 5 04-07-2009 02:37 PM
Handicap curbless shower questions slayer73 Tile Forum/Advice Board 7 09-12-2007 08:52 AM
curbless shower/almost luellendahl Tile Forum/Advice Board 7 09-03-2005 03:55 PM
