Unread 10-23-2007, 09:10 PM   #1
mike051306
Send a message via Yahoo to mike051306
Mike's bath/laundry remodel
hello,
I have read lots of good info on this board, so I thought I would join so I can ask some questions concerning my project.
I am taking a corner of my basement and turning it in to a bath/laundry room. the room is about 10x13 foot, it will end up a little smaller after I get the walls finished.
I am in the process of putting in an egress window, and braking up the floor to redo the DWV pipes. I think I finally have the layout finalized, it has changed a half dozen times.
My wife picked out the floor tile, which is granite. She likes it, and it was on sale, so it will do. We haven't decided on shower tile yet.
We have decided on a custom 48 x 60 shower with a shower head at each end. I was first going to use the Kerdi pan and mortar on two sides to make the length I want, but I have decided to give a try at a custom pan. I will be using the Kerdi drain and the Kerdi membrane. The sales rep told me that I can just cut strips of the membrane to use instead of the Kerdi Band. Although the band is thinner, does it look okay to just use the Kerdi membrane.
1. Do I use the same mud mix with the Kerdi system 4:1-6:1 or can I use something different?
2. It is about 130 lbs of concrete for one cubic foot, right?
3. Can I use the same concrete mix to fill in my basement floor, where I had to brake it out?
4. I got CBU for the shower, but I was first going to do something different, because I changed to the Kerdi membrane, should I return it and get the regular drywall?
5. Should the rest of the room be green board, or would plane drywall be fine?
6. Our house is about 60 years old, and about 25% of the basement floor in the bath area will be new, should I use Ditra under the granite tiles, or if I wait a month before laying the tile should everything be okay? Oh, there will be in floor heating pads under the granite, Suntouch I think the brand is.
I think that is all of my questions for now. I am planning a big trip to HD this weekend, which is about 200 miles away, so I want to get everything if possible, that is the reason for so many questions. It sucks to be in a small town.
Thanks for all the assistance.
Michael
mike051306 is offline   Reply With Quote
Unread 10-23-2007, 09:47 PM   #2
Welcome, Michael.
I added some numbering to your questions for ease of response.
1. Yes.
2. Close enough for any tile project considerations.
3. I would not. I like to use something like Quikrete's regular ol' concrete mix.
4. I would use regular drywall.
5. Regular drywall is fine.
6. I think you might wanna talk to the Sun Touch people about that. If you're talking about a lot of patched concrete down there, you're likely to need some serious crack isolation there. Depending upon how you treat the heating system and the areas around it, it's difficult to know just what you'll need over the top of it all. I'd very strongly recommend you call Schluter directly (800-472-4588) after you've made the decisions about the heating system.
Unread 10-23-2007, 09:56 PM   #3
Assuming the granite tile is polished...be careful...it will be very slippery when wet.
Unread 10-23-2007, 10:59 PM   #4
mike051306
Cx,
Thanks for numbering the questions, I should have done that.
jadnashua,
it is polished, that is why I didn't really want it, but my wife wanted it. We will put down a rug by the shower, so that will help. Maybe we will find something different by the time I am ready to put down the floor tile.
Any recommendations for trowels for the shower pan? I do not have any concrete tools, and I don't want to buy stuff I don't need, or that doesn't do the job right.
michael
Unread 10-24-2007, 08:31 PM   #5
mike051306
What size notched trowel for the granite floor tiles?
michael
Unread 10-24-2007, 09:22 PM   #6
The size trowel to use depends on how flat things are, both the floor and the tile. The worse the surface, the bigger the notch trowel. You need enough so that you get good coverage. If the floor is uneven, you need more to level it out.
Unread 11-23-2007, 04:54 PM   #7
mike051306
okay, I am ready to install my kerdi drain. I have all the plumbing under my basement floor done. I have not pored the concrete back in yet.
1. What is the best way to install the drain in a concrete floor?
a. Should I install the drain on the pipe at the height I want and just push the concrete in around it.
b. Leave an area around the drain concrete free and fill it in when I do the shower pan.
c. something else?
2. Because I will have more then 1 inch under the drain, can I put the drain pretty much at the level of the floor? this would mean the mud would be very thin at the drain location.
3. How long after I pore the concrete floor do I need to wait to pore the shower pan?
thanks,
Michael
