Unread 03-30-2021, 06:38 PM   #1
max 93
Is one uncoupling membrane better than another?
I’m looking at a tile floor install that is concrete with hydronic heat over Spancrete. The original tile install failed with tiles popping of soon after it was done 25 years ago. Pretty sure it was caused by the shrinking of the concrete and no expansion joints anywhere in the concrete or the tile. The customer wants the new tile installed with an uncoupling membrane. What are your thought on Ditra with All Set under the membrane and to install the tile VS Stratamat with 254 to install the membrane and Tri lite to install tile?
Matt
max 93 is offline   Reply With Quote
Unread 03-30-2021, 07:48 PM   #2
In response to your thread title, Matt, I can say with authority that don't nobody know.
Some day, when the industry actually develops testing and a standard for those products, we'll be able at least to show you the test results and let you decide which you prefer. Today, all you have to go by is the various manufacturers' claims. And without a standard, there's no way to dispute any of those.
If you're concerned with crack isolation for the new installation, I recommend you look into a good crack isolation membrane. For those there is a standard -ANSI A118.12.
Unread 03-31-2021, 04:00 PM   #3
Nick Drake
Not a clue on whether either is truly better for crack isolation.
Strata is going to let you use a modified thinset for bonding the tile without an extended cure time with the grace of the manufacture. If it's large porcelain and time is of the job is a factor I'd probably opt strata just for that piece of mind.
Big downside to working on strata, the "hydration vents" in it are pretty uncomfortable on your supporting hand. If it's any sizeable square footage grab a float to rest your hand on when you're prefilling.
Nick
Nick Drake is offline   Reply With Quote
Should You Use An Uncoupling Membrane For This? links1979 Tile Forum/Advice Board 16 07-12-2017 05:46 AM
Uncoupling membrane - Blanke Matt Dworak Tile Forum/Advice Board 4 11-03-2016 08:28 PM
Uncoupling Membrane, do I need it ronbo404 Tile Forum/Advice Board 6 11-19-2013 06:58 PM
re: uncoupling membrane question gramps Tile Forum/Advice Board 8 11-13-2013 07:22 PM
Uncoupling membrane CNM DESIGN Tile Forum/Advice Board 13 02-23-2010 10:20 PM
