Unread 05-03-2018, 11:57 PM   #1
Horner Happiness
Master Bath complete renovation
Hello fellow DIYers and Pros. I’m a very detail oriented DIYer that may have bitten off more than I can chew. My project is a master bath to include laundry with a 3x5 shower (installed Dreamliner Slimline acrylic base in mortar bed). I’m planning to cover the floor with a 12x24 porcelain tile using 1/2” trowel. Over my 1 1/2” plywood subfloor I installed Mapei Floor Tile mortar mixed with latex additive under my fiber cement board (Allura brand) and used proper screws to secure. I have taped my seams between panels with alkali resistant mesh tape. I’m also planning to install a Suntouch radiant heat floor mat. Should I have put a waterproof membrane down before my FCB? Or should I do it now, use Redguard, before installing tile? Hoping I didn’t commit a big mistake. Thank you for reading my 1st post, have a great day!
Michelle
Horner Happiness is offline   Reply With Quote
Unread 05-04-2018, 04:54 AM   #2
Welcome to the forum, Michelle.
Are you wanting to waterproof the entire bathroom floor? If so, for what purpose?
It's not typically needed, but if you were to waterproof it, it would go on top of the cement board.
Unread 05-04-2018, 05:16 PM   #3
Horner Happiness
Thank you, Kman! I wasn’t sure if it was necessary or not in a wet space. I wasn’t planning on using a waterproof grout so thought it might be needed. I’m also putting 3x6 tile in the shower and that has Goboard as the waterproof material. I’ve never tiled a shower before so I’m even more nervous about that. If I am using a glazed ceramic tile on majority of space but want a marble accent stripe about 6’ up & marble pencil edge, which product will be my best bet for adhesion? I have white Flexcolor CQ for grout.
Michelle
Unread 05-04-2018, 06:06 PM   #4
A decent quality modified thinset in white is good for marble. Look for something around $15-20 for a 50lb. bag. That may be higher, depending on your location.
Unread 06-19-2018, 11:40 PM   #5
Horner Happiness
Advice for Mother of Pearl Backsplash
I originally thought I would install these small mother of pearl mesh backed tiles with a combo adhesive/grout unsanded product. Can anyone advise on the least dulling products to keep tiles shiny? Should I use 511 Impreg before I adhere? Helpful info welcomed.
Michelle
Unread 06-20-2018, 03:27 AM   #6
Specifically where is the backsplash? Do you have a link to the mother of pearl tile you plan to install, or a picture?
Unread 06-20-2018, 09:45 PM   #7
Horner Happiness
Kitchen backsplash
The MOP tile is very thin.
Michelle
Unread 06-20-2018, 09:50 PM   #8
Horner Happiness
Not sure why my pic is upside down 🤔...my range will be placed in the opening under the microwave. The adhesive/grout product I found is made by TEC.
Michelle
Unread 06-20-2018, 09:51 PM   #9
Horner Happiness
I’m also considering placing this MOP in a niche in the shower.
Michelle
Unread 06-20-2018, 10:13 PM   #10
Does the MOP manufacturer have installation instructions?
Unread 06-21-2018, 02:01 AM   #11
Horner Happiness
Manufacturer recommends a premium penetrating sealer on stone for natural look. Doesn’t make a recommendation for shell. Specifically says to not allow sealer to dry on shell though.
Michelle
Unread 06-21-2018, 09:30 AM   #12
In such instances we try to get a written statement from the tile manufacturer. A phone call or email usually does the trick. If they refuse, you are sort of on your own. Asking other MOP manufacturers or grout/sealant manufacturers would be the next step.
Unread 06-21-2018, 04:47 PM   #13
I'd make a sample board to experiment with. Then you'll know exactly what to do on your back splash.
Complete Master bath re-model zkm Tile Forum/Advice Board 2 10-23-2014 12:11 PM
Master bath renovation; Shower and bath floor instal dward Tile Forum/Advice Board 16 03-25-2014 11:26 AM
Starting a Master Bath complete remodel Shower first Darren Thomas Tile Forum/Advice Board 21 08-09-2008 03:14 PM
Complete bath renovation by a DIYer soloncamper Tile Forum/Advice Board 2 05-30-2007 02:59 PM
Major Master Bath Renovation Complete JayHill Tile Forum/Advice Board 3 03-06-2006 02:50 PM
