Unread 07-19-2015, 05:45 PM   #1
mcleester
wall and shower pan not in line
I am putting in a basement bath and tiling the shower. The shower pan is not even with the cement backer board for the tile. The pan is one of the ones that is made to be tiled.
Should I build up the wall to even using some thinset (letting it dry before I lay the tiles with thinset as usual)? Take off the cement board and shim it out?
Also, this is my first time doing a shower. I notice with large tiles I get lippage more...I assume this is even worse on a wall. Thoughts on biggest size to go for?
Chris
mcleester is offline   Reply With Quote
Unread 07-19-2015, 06:47 PM   #2
Hi Chris, how thick is the Hardiboard? If it's only 1/4 inch, you may have to remove it and use 1/2 inch.
Unread 07-19-2015, 07:08 PM   #3
mcleester
Looks to be 13/32...so I guess that's the 1/2 inch stuff.
Chris
Unread 07-19-2015, 08:11 PM   #4
I'd shim the walls. Ideally, you want the walls to overlap the flange.
Pedestal Tub over Kerdi Line Shower Pan? ErinM Tile Forum/Advice Board 8 10-05-2013 08:28 PM
Recessed Shower Supply Line Help lovedam Tile Forum/Advice Board 2 04-27-2009 05:48 AM
Grout line size for shower wall jdkimes Tile Forum/Advice Board 5 09-30-2006 01:33 AM
Tiling on Diagonal: follow a wall, snap a line? richb2 Tile Forum/Advice Board 8 01-28-2006 12:59 AM
1/4 slope reference line on shower pan???? unvrknw Tile Forum/Advice Board 6 01-05-2004 08:19 PM
