Unread 08-12-2012, 12:51 PM   #1
mbdreaux
Mortar float over cement slab
I always do mortar floats over wood subfloors, and so just nail the metal lathe to the subfloor with galvanized roofing nails. Now I'm looking at a small, cement slab, bathroom floor, (approx. 20 sq ft) where there is a significant dip where the toilet flange is located. Thinking about floating the floor, but how to get the metal lathe to lay flat? Ideas mud people?
Maia
Maia
mbdreaux is offline   Reply With Quote
Unread 08-12-2012, 02:09 PM   #2
Welcome, Maia.
You would not use metal lath in that mud application.
Your choices are to do a bonded mud bed, in which you apply a slurry of bonding mortar consisting of thinset mortar or pure Portland cement before placing a minimum of 3/4" of deck mud, or you put down a cleavage membrane and place a minimum of 1 1/4" of deck mud with reinforcing mesh (not metal lath) in the vertical center of the mud.
Unread 08-12-2012, 07:08 PM   #3
mbdreaux
Hi CX,
Thanks for the response! So, a "reinforcing mesh"? Do you mean like a crack isolation membrane? Or more like a fiberglass mesh screen?
Maia
Unread 08-12-2012, 07:26 PM   #4
I think Kelly is talking about welded wire, like in this pic.
Unread 08-13-2012, 03:28 PM   #5
mbdreaux
Aha. Yes, Thank you!
Maia
Masonry mortar use as cement mortar for shower tile eyeglass Tile Forum/Advice Board 46 10-31-2010 10:32 AM
How thin to float mortar bed Donnie McCool Tile Forum/Advice Board 9 11-03-2006 11:30 PM
Proper way to float a mud bed on a slab? kagy Tile Forum/Advice Board 4 10-31-2006 12:38 PM
Mortar Float Over Fireplace Bricks chuckster Tile Forum/Advice Board 1 09-07-2003 09:18 AM
Cement mortar sticking to cement mortar John Bridge Professionals' Hangout 12 03-03-2002 10:12 PM
