Unread 03-18-2010, 10:20 PM   #1
pktaske
Nick B
Cutting stone tiles with an angle grinder
Is it possible to get reasonably straight cuts in 4x4 stone tile with an angle grinder?
Nick
www.stillsmallvoice.info
pktaske is offline   Reply With Quote
Unread 03-18-2010, 10:24 PM   #2
Tiletim
Lost in the details
Tiletim's Avatar
if the cuts are going to be exposed I would use wet saw, if hidden(under base board or corner of a shower) it's ok to use a grinder.
Tim
Tiletim is offline   Reply With Quote
Unread 03-19-2010, 12:03 AM   #3
Deckert
The angle grinder will cut it. Is your cut going to be straight enough, clean enough, polished enough, etc..? Only you can answer that once you cut one.
Brannigan
HeenanGC.com
Unread 03-19-2010, 08:29 AM   #4
tiredguy
+1 to what Brannigan said.
I've cut all types of stone tile with a handheld dry saw, you just have to be a bit more on your toes about it. With a smooth (non-segmented) blade you can generally get a clean cut, but it can depend on the particular stone your working with and how your holding your mouth open at the time.
Jason
tiredguy is offline   Reply With Quote
Unread 03-19-2010, 08:53 AM   #5
You hold your mouth open when using a dry saw?
Unread 03-19-2010, 09:00 AM   #6
tiredguy
Yeah? I'm not supposed to? (turns to the side and coughs up loads of grey phlegm).
Hmmm....
Jason
Unread 03-19-2010, 04:20 PM   #7
keithrayhaney
Diamond Blade Supplier
keithrayhaney's Avatar
Yes
As mentioned in the other response, it can be done and you should use a continuous rim and i use a sponge with a little water to keep the dust down. snap a line and go slow
Keith Haney
HaneyRay & Associates
www.tilebladesrus.com
keithrayhaney is offline   Reply With Quote
Unread 03-19-2010, 04:50 PM   #8
tileguynky
Another option is to run a line of masking tape for your cut line.
Angle Grinder - Help with Purchase, please! Vyshtia Tile Forum/Advice Board 5 11-03-2006 07:47 PM
Angle Grinder dilema jknight Tile Forum/Advice Board 15 05-25-2006 11:48 AM
Angle Grinder ? KHF Tile Forum/Advice Board 9 05-22-2006 08:25 PM
Angle Grinder JR Professionals' Hangout 20 12-11-2005 05:53 AM
What is your favorite angle grinder? giarc25 Tile Forum/Advice Board 43 08-25-2005 09:00 PM
