Unread 04-22-2015, 02:53 PM   #1
highschoolhank
Angle grinder speed for cutting porcelain
I need to cut some 6" x 24" porcelain tiles across the 6" dimension. I have a variable speed (max 10,000 RPM) angle grinder and a 4" continuous diamond blade. With the exception of one cut, the cut edges will be hidden.
1) What are the trade-offs between using a higher vs. lower angle grinder speed?
2) In order to make that one exposed cut fairly straight, is it possible, feasible, safe, to use something like a piece of wood clamped to the tile to help guide the blade?
Hank
highschoolhank is offline   Reply With Quote
Unread 04-22-2015, 07:07 PM   #2
Depends on the tile and the blade. The best it to experiment.
Then there is the issue of how much pressure to apply and the speed the tool is moved.....
Unread 04-22-2015, 07:14 PM   #3
Seems like some tiles will cut better on a fast RPM, some better and chip less on slow. The blade probably has something to do with it and how much wear the blade has and how much it vibrates. I would experiment with it.
Running the blade along a piece of wood does work. It may become crooked after several cuts with the diamond running against it. Just don't clamp it so tight that it breaks the tile.
Unread 04-22-2015, 07:52 PM   #4
Heat can cause a tile to shatter, so it depends on your technique and the tile. Water cooling can help, but not all grinders are safe with that.
Unread 04-23-2015, 11:04 AM   #5
highschoolhank
Thanks for all the input. I'd better get to practicing techniques.
Hank
Unread 04-23-2015, 11:45 AM   #6
Have a look at post #27 on this thread, Hank. Review the rest of the thread, too. The blade can make a world of difference.
Good porcelain blade for 4.5 inch angle grinder DannyB Professionals' Hangout 43 10-02-2014 09:33 AM
Variable speed 4" grinder??? figaro Professionals' Hangout 9 07-14-2012 09:18 PM
Cutting stone tiles with an angle grinder pktaske Tile Forum/Advice Board 7 03-19-2010 04:50 PM
Angle Grinder ? KHF Tile Forum/Advice Board 9 05-22-2006 08:25 PM
Angle Grinder JR Professionals' Hangout 20 12-11-2005 05:53 AM
