Unread 06-07-2011, 03:30 PM   #1
jboss
JB
Tile over plaster walls
I am redoing my bathroom, and am replacing the old shower tile with new mosaic porcelain tiles, when I removed the old ceramic tiles the thin coat on two of the walls was cracked and in bad shape. I removed the old thin coat mortar and patched the base coat (base coat is mesh wire over wood studs cir 1958).
My question is: What do I need to do to prep the old plaster for the new thin coat/ tiles?
The old plaster looks like it has some kind of moisture barrier between the plaster and thin coat, it is a dark yellow/brown thin painted coat. Can I just smooth out the old base coat, and roll on a new moisture barrier, then put the tile up using a cement based thin set mortar.
I am not sure that the thin set will stick to the moisture barrier.
jb
jboss is offline   Reply With Quote
Unread 06-07-2011, 09:08 PM   #2
muskymike
muskymike's Avatar
Hi JB, welcome! You will need a waterproofing membrane or a roll on membrane on the walls. You should remove the plaster area around the shower and put up CBU with a vapor barrier or dry wall with Kerdi.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 06-08-2011, 10:00 AM   #3
jboss
JB
Thanks Mike, That sounds like the best plan. The CBU with a
moisture barrier will be much easier to work with anyway.
jb
Tile of Plaster Walls tijcolem Tile Forum/Advice Board 1 03-27-2010 10:51 AM
Glass tile on lumpy, bumpy plaster walls PamelaG Tile Forum/Advice Board 7 12-19-2009 06:39 PM
Tile over plaster walls in shower IndyDog Tile Forum/Advice Board 1 02-07-2009 09:19 AM
Tile over new plaster walls FCollins Tile Forum/Advice Board 10 08-29-2007 05:36 PM
Tile over old plaster walls askme233 Tile Forum/Advice Board 3 04-05-2006 01:01 PM
