Unread 05-25-2008, 07:21 PM   #1
BrianL
Thinset differences
Hello all,
Just set a 18" porcelin tile floor, using white Versabond thinset. Halfway through, ran out but had 1/2 bag of white Megabond thinset. All went well, the next day was cleaning up the grout spaces preparing to lay grout, and noticed a big difference in strength. The Versabond was very hard, almost too hard to clean out any extra bits in the grout space while the Megabond grumbled quite easily.
Both were fresh bags, bit mixed according to directions. Layed on 1/4" Hardi, lightly misted with water prior to laying tile.
Any thoughts? Am I OK to continue?
--Brian
--Brian
BrianL is offline   Reply With Quote
Unread 05-25-2008, 08:03 PM   #2
Ken
welchtile.com
Did you mix the Megabond with the admix instead of water?
LATICRETE Mega Bond must be fortified with LATICRETE Mega Bond Additive for exterior use, impervious tiles, porcelain, mosaic, glass and stone tiles, heavy traffic areas, exterior glue plywood, and cement backer boards.
Versabond out of the bag is a modified thinset, megabond is not without using the LATICRETE Megabond Additive. This is why you're noticing the difference in strengths.
Ken
Ken is offline   Reply With Quote
Unread 05-26-2008, 04:43 AM   #3
BrianL
Aaaarrrrghhhhh! Nope, used water for both. Now what? Tear up the second half? Just for giggles I tried to pry up one of the tiles, and it is seated very firmly. No dull sounds when tapping on the tile.
It is a bathroom, so lots of use, but not what I would call heavy traffic!
Thanks for the advice.
--Brian
--Brian
Unread 05-26-2008, 04:56 AM   #4
kerdibird
Leave it be
You should be ok if they don't sound hollow.
kerdibird is offline   Reply With Quote
Unread 05-26-2008, 10:06 AM   #5
yeah Brian, you'll be fine.
don't let him scare you with technical data he posted about a thinset with Additive in it.
the Megabond is a good unmodified thinset and will hold your Porcelain tile.
Unread 05-26-2008, 06:05 PM   #6
BrianL
Awesome, thanks all for the advice.
--Brian
--Brian
