Old 07-02-2010, 08:37 PM   #1
Levi-C
Levi-C's Avatar
Ardex liquid backerboard
Has anyone had any experience using ardex liquid backerboard? I have never used it, but I have a situation where the subfloor needs to be leveled, and I can't use regular slc due to it needing to be 1/2 inch over the high point. I was a little skeptical about a product that can be poured 1/8 inch thick, and doesn't require metal lath, but it seems to be the only product that qualifies, so I bought 20 bags, and I even bought the mixing drum, along with a spreader. It was expensive, so I hope it does the job.
Thanks, Levi
Levi Clark Masonry & Tile LLC
San Juan County, WA
www.LeviClark.com
Levi-C is offline   Reply With Quote
Old 07-03-2010, 02:02 AM   #2
Dave Taylor
Dave Taylor's Avatar
Levi.......
Sounds like you got yourself a job there.
I'm gonna' move your question on over to the "Professional Hangout" and leave a link to it here in the "Advice Board".
You may get better response this way.
Dave T (DIY'er)
the net.
Old 07-03-2010, 04:15 AM   #3
Autoplay
Tile Setter
I've never heard of Ardex "liquid backerboard",but I have heard of Ardex feather finish products.
I've used Ardex feather finish products,going from zero to say 1/2",and I'm extremely confident in the results and longterm ability of the product!
Like you stated,it is expensive,but well worth it when locked into height restrictions.
Rich
Old 07-03-2010, 05:30 AM   #4
I use ardex thinset, they make really good stuff.
Old 07-03-2010, 08:19 AM   #5
CSS
CSS's Avatar
Have heard of it but not used the liquid backer. i have used thier gs-4 on several jobs it can be poured over plywood with no lathe also just prime and go. All ardex products i've used are very good. I like the 8+9 waterproofing alot also.let us know how this liquid backer works.
Robo
www.webspawner.com/users/premiumtileguy
CSS is offline   Reply With Quote
Old 07-03-2010, 08:24 AM   #6
Shaughnn
Trowel Monkey
Shaughnn's Avatar
hi Levi,
I'm not familiar with the product either. Where do you buy your Ardex through? Don Richards is their local rep, last I knew. If you have any issues or need to consult his number is (###-###-####)
Best of luck and please let us know your impressions of it.
Shaughnn
Old 08-02-2010, 09:46 PM   #7
Shaughnn
Trowel Monkey
Shaughnn's Avatar
I just heard from Don Richards today and the contact phone number I had for him is out-of-date. The following is his contact information in case anyone has questions about Ardex products. I've invited Richard to respond to related questions and I hope to see him posting soon.
Don Richards, CSI, CDT
Ardex Engineered Cements
WW Henry Company
206-979-0401 cell
www.systemonesolutions.com
Old 08-03-2010, 06:48 AM   #8
Levi-C
Levi-C's Avatar
I bought it at the cronin company out in kent. They seem to be the only people who actualloy stock it around here. I am getting ready to pour soon.
Thanks, Levi
San Juan County, WA
www.LeviClark.com
Old 08-03-2010, 07:28 AM   #9
Shaughnn
Trowel Monkey
Shaughnn's Avatar
Hi Levi,
When I spoke with Don he indicated that their products has about 20 minutes longer working time, which I think makes it comparable to the "LevelQuik ES". Please let us know your impressions?
Shaughnn
Old 08-13-2010, 05:25 PM   #10
Levi-C
Levi-C's Avatar
I just finished 2 pours using ardex. It seems to be a good product. It seems a little bit more liquid than other slc's that I have used in the past. I mixed 1 bag at a time in the mixing drum made by ardex. I didnt have to rush at all. I bought an adjustable spreader, but I ended up using a squeege because I poured over electric in floor heating cables. The squeege was just fine. I wouldn't waste the money on the spreader. The stuff flows so nice that you dont need it. It was workable for at least 30 minutes, and I could walk on it in a couple of hours.
Thanks, Levi
San Juan County, WA
www.LeviClark.com
Old 08-13-2010, 05:33 PM   #11
Levi-C
Levi-C's Avatar
I am assuming that most people lay tile directly over slc's, or liquid backerboard, but I was planning on putting a anti fracture membrane over it just to be safe. I bought some "bostik gold plus" the other day when I was in a hurry, and I have never used it before. It appears to be somewhat like redgard, but a little thicker. No fabric required. I was reading the instructions, and noticed that it was not to be used over gypsum type cement floors. But it is ok for just about everything else. I don't know if ardex is full of gypsum, but I would like to use something as a crack isolation membrane. I will call the tech dept at ardex monday, but do most of you just set tile right on top of slc? I don't have a ton of experience with this. Thank's
Thanks, Levi
San Juan County, WA
www.LeviClark.com
Old 08-13-2010, 05:36 PM   #12
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
Pretty sure the Ardex product is not gypsum based but is Portland Cement Based. Go online and look up their spec sheet or MSDS. It should tell you.
I would think you should be fine installing the membrane over the slc.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Old 08-21-2010, 09:36 AM   #13
CSS
CSS's Avatar
a little late but ardex 8+9 is some good stuff and dries real fast.
Robo
Old 09-04-2010, 11:37 PM   #14
Don Richards
I hope your experience with liquid backer board has been positive. Liquid backer board has a longer working time and more yeild per bag then any other Ardex self leveler including GS4 but GS4 has a higher psi both contain gypsum and should only be used above grade. Ardex has other self leveling products that are portland cement. 8+9 is a waterproofing and crack isolation product that is very compatible is easy to use and is inexpensive.
Don Richards
Don Richards is offline   Reply With Quote
Old 09-05-2010, 06:48 AM   #15
Welcome aboard, Don.
If you're an Ardex guy we'd like to know. You seem to know a lot about the products. Give us a little background, will ya?
new ardex liquid backerboard?? tessy78 Tile Forum/Advice Board 1 02-20-2010 03:39 PM
Ardex Liquid Backerboard jadnashua Tile Forum/Advice Board 6 12-17-2009 08:14 PM
Ardex GS-4 lou432 Professionals' Hangout 4 11-02-2009 05:26 AM
Ardex 8+9 muskymike Professionals' Hangout 18 10-23-2009 09:27 PM
Ardex K-15 John K Professionals' Hangout 6 03-05-2009 05:53 AM
