Old 07-12-2012, 10:18 PM   #1
Tiger Mountain Tile Inc
tile lackey
Tornado Leveling System
I received an email about this system today. You guys that use these things, what do you think?
It looks like Midwest Trade tools has them.
Jim Upton
DIYTileGuy
Old 07-12-2012, 11:05 PM   #2
I can see a few down sides to the huge ring and needing two hands to install.
LASH is still better and simpler.
Old 07-12-2012, 11:46 PM   #3
Shaughnn
Trowel Monkey
Shaughnn's Avatar
Still too much wear on my fingertips. I like my gun, thankyouverymuchsir.
Shaughnn
Old 07-13-2012, 07:29 AM   #4
pgc555
What I see is that the installer forgot ( or just doesn't ) Back-butter the tile.
The two handed piece to this type of "leveler" would be a negative.
http://tiletools.com/us/rtc-tornado-leveling-system/
Phil,
http://www.edgestripkits.com/
pgc555 is offline   Reply With Quote
Old 07-13-2012, 07:51 AM   #5
Sprung831
Tile Tool Guy
Sprung831's Avatar
He didn't back butter because it was strictly a marketing video, and they were trying to keep it as short as possible. I've seen some comments that people have made about the "two handed" operation being a negative, but they don't explain why they think it's a negative. I am the one who tested this system, and I think it is outstanding. I myself would choose this over RLS any day, and although I am a Tuscan fan, the Tornado is much less expensive.
It does not take much force at all to twist the ring, and since there is no mechanical tool involved, you don't have to worry about the base breaking prematurely. This in turn makes it so you don't have to soak the bases.
Also, if anyone has taken a look at the photos on tiletools.com, you will see that it's also unique in the way that if you are using it with a smaller tile (12, 13, 14, 16), you have the ability to use just one base and ring at the intersection of all 4 tiles.
Steve Sprung
Technical Manager
Midwest Trade Tool
www.tiletools.com
Sprung831 is offline   Reply With Quote
Old 07-13-2012, 08:45 AM   #6
I'd be happy to give some samples a test drive.
Just looked at the price its pretty good. TLS = $1.06 per cap and 6 cents per strap while LASH is 10 cents per T and 10 cents for each wedge. Tornado rings are 2.6 cents each with the bases at 1.2 cents as best I can tell.
Old 07-13-2012, 08:55 AM   #7
Sprung831
Tile Tool Guy
Sprung831's Avatar
You're on the list Paul! We should have it here in about a month.
Steve Sprung
Technical Manager
Midwest Trade Tool
www.tiletools.com
Old 07-13-2012, 08:57 AM   #8
That's great. I like the LASH due to its simplicity and this system looks straight forward as well.
I'm looking forward to the samples.
Old 07-13-2012, 08:58 AM   #9
cwilde72
cwilde72's Avatar
Steve, didn't you show us some pics of a floor you did utilizing this system while it was still in the testing phase? Coulda swore you did
No need to soak straps, no special installation tool required, can be used at corners, less money. Sounds like a winner to me!!!
Chad Wilde
Precision Tile
Huron, SD
cwilde72 is offline   Reply With Quote
Old 07-13-2012, 09:25 AM   #10
silvercitytile
silvercitytile's Avatar
I would also be interested in the testing
This looks like a very useful system
Castillo Construction
Old 07-13-2012, 09:32 AM   #11
java
Hugging Trees Oct. 1st
java's Avatar
I've never used any leveling system.
You need more testers let me know.
Jason
java is offline   Reply With Quote
Old 07-13-2012, 09:59 AM   #12
Executive Flooring
Executive Flooring's Avatar
Seems like an ok system but I think your fingers would be hurting quite a bit after a long day. Especially with bigger/heavier tiles. I like the fact that with my Tuscan gun, it take some of the work out of it.
I remember doing a job with the Lash system before I really knew about the Tuscan system and my fingers were killing me by the end of the day. That was the last time I ever used that system.
I will say that the pricing looks pretty attractive though. I think we need some real world testing and experience.
Ray
MA/NH Home Remodeling
Executive Flooring is offline   Reply With Quote
Old 07-13-2012, 10:00 AM   #13
Joel@RTC Products
Account Manager
Joel@RTC Products's Avatar
The Tornado System will be a great option to the TLS system. While both have their advantages, the Tornado system excels in its simplicity, it's cost (or lack there of), and the fact it WORKS! In response to the oversized rings, and to the "wear on your fingers", that's why the Rings are oversized, to prevent wear and tear on your fingers by being larger, they provide more torque. Also, as Steve said, there will be some applications where only ONE base and ring set will be needed on the corner of 4 tiles. In one month, we'll know for sure, but based on the feedback we got from contractors using this system during our manufacturing process, this system is going to be a winner.
Joel
Joel@RTC Products is offline   Reply With Quote
Old 07-13-2012, 10:21 AM   #14
jnugget
jnugget's Avatar
they could probably make some type of socket that would fit over the blue caps with a short t-handle or a big plastic box wrench. Looks like a decent system, if it's cheap enough, would certainly be worth a try.
John
jnugget is offline   Reply With Quote
Old 07-13-2012, 10:44 AM   #15
StoneTooling
Vending Machine
StoneTooling's Avatar
I've been avoiding making a thread for new leveling systems but now that there is one I'll add my 2 cents.
We have been getting so many manufacturers coming to us with their systems lately and most of them are modeled after the TLS. Even Rubi has gotten into the game with theirs.
I can see how installers may like having the free hand since the TLS uses the downforce and this would require a second hand to prevent the strap from twisting under the tile.
I'm looking forward to hearing installer reviews!
Lauren V.
StoneTooling Now shipping internationally!
Visit us and purchase through the sponsored link at the bottom of the page to support the JB forums!
Contractors - send us your information to be listed on our contractor page.
StoneTooling is offline   Reply With Quote
Leveling System Saldibs Professionals' Hangout 21 02-01-2012 04:09 PM
tuscan leveling system tiborodriguez Tile Forum/Advice Board 8 11-27-2010 10:42 AM
Tuscan Leveling system TimJar Tile Forum/Advice Board 12 10-05-2009 01:11 PM
