Old 07-14-2012, 07:01 PM   #1
The Kid
The Kid's Avatar
slab shower dead load concerns
I have a bathroom coming up that I will do the prep work for a fabricator. My work will include install cbu, mud pan with linear drain, float tub deck for undermount tub, tile floor and shower pan.
The fabricators work will include fab and install 2 shower walls (5'x8'), tub deck (40"x8'), tub splash (16 lf x 12"), tub skirt (20"x 8'), vanity tops (12lf x21") all in 3cm material.
My concern here is creep deflection on the wood frame floor with all the weight of the stone. Any enjineers out there care to comment on this? The joist are 2"x10" with the span being unknown at this point. Am I asking for it if I tile this floor?
Jeremy
Cascade Tileworks,llc
Licensed, Bonded & Insured
WA Lic# CASCATL894QA
The Kid is offline   Reply With Quote
Old 07-14-2012, 07:10 PM   #2
Davestone
Florida Tile & Stone Man
Maybe,have you checked the floor structure on the DEFLECTO above?
http://Davestonestile.com
Old 07-14-2012, 07:23 PM   #3
PetrH
most buildings are designed for a load of 40 lbs/sq.ft. That adds up to about 4000 lbs for a 100 sq. ft. bathroom. If you add up all your rock, finishes, and a large tub full of water, you will be getting close to that. IMO it's worth mentioning your concerns to the homeowner and see if they want to pay for a consult with a building Engineer, or at least a master carpenter.
Petr
PetrH is offline   Reply With Quote
Old 07-14-2012, 07:28 PM   #4
dhagin
Good questions. Got a drawing?
edit: 40 lbs/sqft dead load or the whole building, Peter? Around here, typical minimum design for residential floors is 10 - 20 lbs/sqft dead load, depending on the room, with 40 lbs/sqft for live loads.
dana
Old 07-14-2012, 07:41 PM   #5
Da Home Builder
Not close to enough information there, Jeremy.
But based upon what we've got I'll say it'll either be OK or it won't. But that's just a guess.
Old 07-14-2012, 07:47 PM   #6
gueuzeman
That's the kind answer I like, CX. I concur.
gueuzeman is offline   Reply With Quote
Old 07-14-2012, 11:19 PM   #7
Levi the Tile Guy
Tile and Stone Contractor
Levi the Tile Guy's Avatar
Levi The Tile Guy
Grand Junction, Colorado Tile and Stone installation
Levi the Tile Guy is offline   Reply With Quote
Old 07-14-2012, 11:59 PM   #8
The Kid
The Kid's Avatar
The deflecto rates the floor at around 588, so were good there. However, im concerned how the unaccounted weight might affect this floor over time.
Thanks for stating the obvious Kelly.
Jeremy
Old 07-15-2012, 08:06 AM   #9
Da Home Builder
Always glad to help, Jeremy.
It's really just a basic math problem, but you gotta fill in all the numbers to complete it. It's not complicated, but it's not anything any of us can see from out here, eh?
Old 07-15-2012, 12:36 PM   #10
dhagin
An engineer will want a drawing with some/all of this stuff - joist specie, grade, size, spacing, spans; locations of bearing walls below; weight/sqft of stone; size & locations of all stone; floor tile install method & weight/sqft; tub location; anything else that adds to floor/wall loads; etc... you know, all the usual stuff.
My local engineer will do these for me quick & often free with nothing in writing. For signed, stamped paperwork he'd charge the minimum - usually 100-150. Whether i get something in writing often comes down to my comfort level with what he says.
dana
Kitchen on slab, few concerns before starting WillFeeny Tile Forum/Advice Board 7 01-24-2011 09:01 AM
I think I will be dead before I get a shower Denhunter Tile Forum/Advice Board 18 12-16-2009 02:35 PM
Need help with Dead Load for Porcelain JeffnJill Tile Forum/Advice Board 18 09-26-2008 04:38 PM
Dead load ratings, and wall flexibility protile Tile Forum/Advice Board 3 12-26-2007 08:04 PM
Deflection help - live load or total load jeffdeline Tile Forum/Advice Board 19 01-08-2006 10:22 AM
