Unread 12-19-2009, 12:10 PM   #1
8ballz73
diagonal on a 30 sq. ft. bathroom
hi everybody new to this site and to tiling. had a couple of questions, i have a 30 sq. ft. bathroom area to tile and the wifey wants it diagonal and the tile she liked only comes in 16 x 16,would it look right going diagonal or would it be better to go squared based on the size of the area? also if i go squared on the floor do i have to go squared on the bathtub surround or can i go diagonal? thanks for any advice!!!!!!
Abel
8ballz73 is offline   Reply With Quote
Unread 12-19-2009, 12:17 PM   #2
Welcome, Abel.
If Mrs. Abel wants it on a diagonal, it will most certainly look best on a diagonal. That's in Tiling 101.
Unread 12-19-2009, 12:21 PM   #3
Saldibs
Tile Contractor -- Boston North Shore
Saldibs's Avatar
Send a message via ICQ to Saldibs
Like CX said if the wife says diagonal, then go with the flow. Actually a diagonal in a small space and large tiles might just be the way to go, and no you don't have to do the same on the walls as you do on the floor. What you like is what is right.
Sal
http://www.youtube.com/saldibs
There is a right way and a wrong way, take your pick!!
You can only choose one!
elitetileco.com
Saldibs is offline   Reply With Quote
Unread 12-19-2009, 01:11 PM   #4
No, the floor and walls don't have to be laid in the same orientation. Considering that a diagonal floor is quite a bit less challenging than a on the walls, you might wanna take that into consideration.
Unread 12-19-2009, 01:21 PM   #5
ih8caulk
ih8caulk's Avatar
I 2nd the "what wifey wants, wifey gets" advice! (You wanna eat tonight, right?)
And I also 2nd the mixed lay pattern. I went with diag/straight/diag to break the patterns up and couldn't be happier. Pics of my finished product on page 3 of my sig below!
Randy...... a. Disorderly, riotous. (Noah Webster 1828)
...... a. Aroused (Princeton.edu 2009)
Randy's Shower Project 2009
ih8caulk is offline   Reply With Quote
Unread 01-29-2010, 12:40 AM   #6
8ballz73
bathtub surround starting point
hi,new here and to tiling,getting prepared to tile a standard bath surround.i'm using 12 x 12 tiles in brick layout on a 8ft ceiling but i believe the measurement from above the tub measures 6' 7". where would be my starting point if i want the pattern to wrap around and also what type of mortar should be used for a beginner like me,thanks
Abel
Unread 01-29-2010, 01:15 AM   #7
Tiletim
Lost in the details
Tiletim's Avatar
Depends, is it a standard tub surround (3 walls)?
Tell us how the surround was built. (from the studs out)
On typical surrounds I start in the middle of the back (long) wall - centered then just wrap my corners to the next wall.
For the height make a story pole or stick - take 3 tiles and lay them on the floor with the grout spacers you want - then lay the stick even with one end of the tile - go the other end of the "stacked" tile and mark that.
now you have a story pole and can figure out you vertical layout but laying the stick on the wall and transferring the marks to the wall.
when you get near the top you will know if you have to adjust the layout downward or not. you want to balance the top and bottom cuts to look the best. This depends on your pattern though.
Tim
Tiletim is offline   Reply With Quote
Unread 02-04-2010, 09:25 PM   #8
8ballz73
redgard question
preparing a standard 3 wall bath surround for tile and going to be using redgard for water proofing,wanted to know if the screws have to be covered with thinset before redgard cause a few are sticking out a little,i already covered the joints w/tape and thinset.just wanted to make sure i do it right. i had a thread but couldn't find it
thanks
Abel
Unread 02-04-2010, 09:35 PM   #9
Shawn Prentice
The screws sticking out might give you trouble setting tiles over it depending on how far. Try to set them. Do you have an impact driver? That'll do it. Or back them out, countersink the hole a bit, then reset.
No need to thinset the screws before redguard. Also, I know the directions say 2 coats for waterproofing, but personally I'd go for 3 just to be sure. You need a pretty good dry mil thickness to get waterproof capability (the thickness of a credit card over the entire surface when dry.)
Shawn Prentice is offline   Reply With Quote
Unread 02-04-2010, 10:03 PM   #10
MNTileGuy
Central Texas Tile Guy
I redgard right over the screws. Like Shawn said, protruding screw heads may give you grief when setting the tile. Get them flat with the board first and you should be good to go.
Brad Bressler
Bressler Tile and Stone
www.bresslertile.com
Unread 02-04-2010, 10:28 PM   #11
I've combined your three threads here, Able. If you'll bookmark this one with your Favorites and use it for all your project questions it'll help folks see what you're working on and what's been previously asked and answered.
Unread 02-04-2010, 10:35 PM   #12
Like they said, drive in the screws the remainder of the way and waterproof away.
Have you already purchased the RedGard? I ask because I prefer Hydroban for it's cost effectiveness and performance. The RedGard is cheaper, but a gallon ($42) only covers about 35 sq/ft when two coats are applied at the proper thickness...that's not enough for most tub surrounds, so a second gallon is needed and you end up paying $84.
Hydroban is a little more pricey at sixty-something bucks a gallon, but it covers a full 50 sq/ft when two coats are applied at the proper thickness. Provided you don't need more than 50 sq/ft of waterproofing for your surround, Hydroban is a better value...and it sticks much more tenaciously than the RedGard.
Unread 02-05-2010, 12:21 AM   #13
8ballz73
haven't purchased the redgard,i went to home depot after my last post on the way to pick up my daughter from school to get some prices and it's forty something for a gallon and a 3 gallon bucket is $120 something. the sq. ft. i need to tile is about 70 sq. ft. Would it be better to go with hydroban or redgard or is there something else i can use?? by the way i forgot to mention that i put a tile underlyment paper which i think is a moisture barrier that i bought at home depot which i believe it said waterproof on it but can't remember,if that's the case can i get away with not using redgard. i'll double check on the name brand cause i couldn't find it online.... thanks everyone for the input and thanks cx for finding the threads!!!!
Abel
Unread 02-05-2010, 11:16 AM   #14
Abel, it'd help if you could find what you used and where you used it. Waterproofing is much too important to skip or do incorrectly. In the grand scheme of things, $120 is not too much to spend to protect your house from rotting away from your shower.
Unread 02-05-2010, 12:10 PM   #15
8ballz73
completely agree with you bob, the stuff is called aquabar "b" and i used it behind the cbu overlapping the tub lip, i installed it before i found this site and didn't know much of what was needed for tile installation. so do you think the 3 gallon bucket should be enough for the 70 sq. ft.? just searched online and is not a water proof membrane.
Abel
Starting point to place tile on wall Yambo Tile Forum/Advice Board 3 01-17-2010 10:57 PM
Finding starting Point for wall tile PapaGCubed Tile Forum/Advice Board 2 05-05-2008 02:26 PM
Starting Point Measurement tanda4 Tile Forum/Advice Board 4 07-11-2007 10:35 PM
starting and stopping point when grouting BlueCanyon Tile Forum/Advice Board 14 12-12-2006 01:49 AM
How to determine center starting point when walls are not square MaryAnnKacz Tile Forum/Advice Board 7 07-24-2006 11:17 AM
