Unread 10-27-2009, 08:01 PM   #1
ih8caulk
ih8caulk's Avatar
Moisture handling in U.S. vs Canada.......
If anybody else has seen the Holmes on Homes episode called "Pasadena 911" there were a couple cool points they talked about.
This isn't directly tile related but interesting....(at least to me)
One of Holmes helpers (Damon) was baffled that he was asked to put a sill board right onto the concrete foundation. "It's pressure treated and all, but we use a barrier between wood & concrete up in Canada. It's against everything I've been taught, but I'll do it.".
Then, later Holmes himself is amused watching the U.S. contractor putting some plastic down, then sand on top before pouring concrete. He confirms the idea with the U.S. GC and then explains to him how, in Canada, they do a 3/4" crushed stone bed with no plastic beneath, allowing water to drain under so it isn't wicked back up into the concrete. Then he just mentions that it's interesting to see different ways of doing things.
I believe later on in the episode Holmes mentions the sill plate thing again as he's just baffled that PT is going down directly onto concrete which is a big no-no in Canada.
Maybe Canada just doesn't use a visqueen type barrier beneath any concrete substrates???
Randy...... a. Disorderly, riotous. (Noah Webster 1828)
...... a. Aroused (Princeton.edu 2009)
Randy's Shower Project 2009
ih8caulk is offline   Reply With Quote
Unread 10-27-2009, 08:38 PM   #2
MNTileGuy
Central Texas Tile Guy
I remember seeing an epsiode once where they were doing a laundry room floor. The had to have a liner that went up the wall I don't remember how many inches. That was a new one to me!
Brad Bressler
Bressler Tile and Stone
www.bresslertile.com
Handling floor registers LindaB Tile Forum/Advice Board 2 04-26-2009 06:17 PM
Handling Disappointment kate42 The Mud Box 13 10-19-2007 06:52 PM
Handling asbestos Bill Vincent Professionals' Hangout 3 10-22-2005 01:50 PM
Handling plywood flooring sheets maiwalhe Tile Forum/Advice Board 5 04-06-2005 12:06 PM
Handling existing back splash transition regas99 Tile Forum/Advice Board 2 03-04-2004 10:50 PM
