Unread 09-24-2020, 10:23 PM   #1
ih8caulk
ih8caulk's Avatar
Aligning frameless shower door???
Whew....been a minute since I’ve been here. Miss the journey from (gulp) 11 years ago I had here!
My favorite shower is still doing great but....my shower door has worked it’s way out of alignment & I don’t know why. Suggestions to get her to hang straigh again? TIA!!
Randy...... a. Disorderly, riotous. (Noah Webster 1828)
...... a. Aroused (Princeton.edu 2009)
Randy's Shower Project 2009
ih8caulk is offline   Reply With Quote
Unread 09-25-2020, 07:29 AM   #2
Welcome back, Randy.
If the door and panel were aligned and now they're not, either the framing moved or the hinges are wearing.
How far off is it now, and which - the panel or the door?
Unread 09-25-2020, 07:36 AM   #3
ih8caulk
ih8caulk's Avatar
Thanks Dan!
Definitely the door. The adjacent glass is stationary. I can get the door very close if I pull it to parallel and and slowly release my hand but it still wants to fall away (toward the outside) about a half inch leaving a little gap.
While I do live in earthquake country, there's no evidence of movement (cracking of any kind....even in the grout) so I guess I'd suspect the hinges are worn. I just didn't know if there was any kind of adjustment in them to compensate.
Thx!
Unread 09-25-2020, 11:53 AM   #4
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Has the distance from hinge side door-to-wall changed? I'm pretty sure this style of hinge clamps the glass in place. If it's sagging, loosen clamp, shim at bottom opposite hinge and tighten clamp.
I'd use two opposing wood shims and snug up to bottom of glass on curb, then loosen, use shims to lift door and retighten. Two people would be nice, one inside, one out. You don't want to pry at the edge of tempered glass, which can lead to a big expensive surprise!
Peter
Unread 10-18-2020, 08:36 PM   #5
ih8caulk
ih8caulk's Avatar
Whew! Sorry so long to reply. I’ve actually been dealing with a flooring nightmare that has consumed most of my time the last few weeks.
Anyway, in answer to door placement, I’m about 99% sure it hasn’t budged but maybe 1/16” since new. It is literally about dead on all 3 contact sides from new. I’m thinking hinges but considering having the original glass folks take a look.
frameless shower door, 34 or 24+10 guoxiaotian Tile Forum/Advice Board 31 11-17-2018 12:45 AM
Frameless Shower Door in CT diy-faq Professionals' Hangout 3 08-13-2018 01:26 PM
Frameless Shower door help FrankCouture Tile Forum/Advice Board 2 08-17-2006 12:11 PM
Frameless Shower Door macbillybob Tile Forum/Advice Board 20 05-11-2006 03:36 PM
frameless shower door maltesegal Tile Forum/Advice Board 1 01-25-2004 09:35 AM
