Unread 02-01-2023, 09:28 AM   #1
SDSailor
Underlayment for Tile - Type of Plywood
Planning to re-tile hallway. Details as follows:
- I-Joists 19.2 inch o/c
- Subfloor 3/4 inch OSB - originally nailed so have added screws
- Underlayment (1/2 inch plywood) - planning to screw down but not into joists
- Ditra
- Ceramic tile
What kind of plywood should I use:
- Spruce, Fir or Pine?
- Does it need to be good one side?
Am in Ottawa, Canada.
Thanks for the help in advance!
Craig
SDSailor is offline   Reply With Quote
Unread 02-01-2023, 11:32 AM   #2
Welcome, Craig.
If you don't add that geographic location to your User Profile it'll be lost before we leave this page - and it's important.
I'm not as familiar with your CANPLY as I am with our APA down here, but what you want down here is an exterior glue plywood with no face of grade lower than C. Doesn't need to be your Douglas Fir Plywood (DFP) and could be any of the Canadian Softwood Plywoods (CSP) as far as I know. I'm not at all sure what your tile industry folks (TTMAC) specify, but you could maybe check that out.
Google up CSA 0151 and see what you can find. But, again, exterior glue and no face of grade lower than C is essentially what you're looking for. Grades AC, BC, CC down here, but I think the classification is different with Canadian plywood.
Unread 02-01-2023, 02:15 PM   #3
SDSailor
Many thanks CX! Appreciate the advice immensely.
Craig
Craig
Unread 02-01-2023, 02:18 PM   #4
Craig, if you're using Ditra as your tile underlayment, that second layer of plywood is structural subflooring. My advice is still the same, but the terminology is so frequently misused in the industry, eh?
Unread 02-01-2023, 04:13 PM   #5
SDSailor
CX,
Thanks for the clarification on terminology. Just checked my local big box store and have reviewed some great information from the Canadian Wood Council (cwc.ca/wp-content/uploads/2020/04/Plywood-Grades.pdf).
I can easily get CSA 0151 (CSP) Sheathing (SHG) which has the following veneer grades: Face (C), Inner Plies (C) and Back (C). The documentation from CWC indicates this is typically used for "Roof, wall, and floor sheathing".
CSA 0151 (CSP) Select (SEL) would have a (B) grade veneer for the face, (C) for the other two veneers. CWC states it is typical for "Underlayment, combined subfloor and underlayment, sheathing, hoarding and packaging".
It seems like what I am doing (in terms of CWC language) is the "combined subfloor and underlayment" (structural sub flooring in your terms). Do I have that right and should I shop around for the SEL grade plywood?
Craig
Craig
Unread 02-01-2023, 04:45 PM   #6
I'm only guessing that both are exterior glue plywoods, Craig, but I don't know how you tell from their markings.
The CCC would be adequate to your needs, if there is a difference in ease of sourcing one or the other or a major price difference. You have no need for a face grade above C and it appears all iner plies are also C grade.
Prepping for new tile job over plywood underlayment exlibris Tile Forum/Advice Board 4 02-15-2023 08:22 PM
What type of underlayment for slate tile on 1 1/8" OSB T&G, & deflection L/1601? Susanne Tile Forum/Advice Board 17 05-05-2020 08:18 PM
Condo floor tile job - best type of underlayment NewbieMcTile Tile Forum/Advice Board 5 10-28-2013 04:17 PM
What type of underlayment for tile table top? oma Tile Forum/Advice Board 2 06-15-2005 05:56 AM
plywood underlayment + tile toolguy Tile Forum/Advice Board 4 01-04-2002 04:31 PM
