Unread 02-01-2023, 08:38 AM   #1
bwooten
Quick Kerdi drain installation question
Hi everyone! First post here, I'll try to make it brief:
We gutted a shower alcove, hired a Schluter wizard to do the waterproofing work (Kerdi board/Kerdi shower tray with 4" Kerdi drain) and I'm taking over for tiling. I have some tiling experience, but this is my first shower floor. We're using 2"x2" square mosaic floor tiles.
I've done the dry-fit, and the drain grate fits SNUG up against the 8 tiles that surround it - no daylight/no room for a grout line around the drain grate. Should I be concerned about whatever water will most certainly get between the tile edges and the drain grate? I assumed I'd have to file the inside edges of the tiles to make space for a grout line, but our Schluter wizard said perfect, leave it as-is... just hoping for some verification on that (or a refutation?) I'll be using Schluter All Set for the tile work.
Thanks a lot!
BEN
Last edited by bwooten; 02-01-2023 at 09:46 AM. Reason: Attempting to add an image...
bwooten is offline   Reply With Quote
Unread 02-01-2023, 09:40 AM   #2
Lazarus
Lazarus's Avatar
Instead of the drain, if you have access to a wet saw, you could certainly trim a sixteenth or so off of the tiles that abut the drain.
Unread 02-01-2023, 09:48 AM   #3
bwooten
I meant diamond filing the inside edges of the 8 surrounding tiles. I've edited the original post to reflect that. Apologies.
BEN
Unread 02-01-2023, 11:04 AM   #4
The water getting through isn't an issue. The expansion of the tile is, considering there's no room there. Maybe just shave a bit off each tile as suggested and run with it.
Unread 02-01-2023, 11:17 AM   #5
Welcome, Ben.
That's the only application I'm aware of where the ceramic tile industry standards specifically allow the use of grout in joints between tile and dissimilar materials. You can cut down the tiles as suggested and grout the new joints, or you can probably get away with leaving it as is. See my warranty information below.
Kerdi Membrane Installation Quick ?'s userbob Tile Forum/Advice Board 13 08-22-2012 07:06 AM
Quick Drain Installation John R Tile Forum/Advice Board 5 01-09-2009 05:59 PM
Quick question about my Kerdi drain before I go any farther Shinbreaker Tile Forum/Advice Board 12 12-23-2008 06:57 PM
Kerdi floor drain installation question larry528 Tile Forum/Advice Board 7 09-09-2007 06:39 AM
Quick Kerdi drain question Paul Singer Tile Forum/Advice Board 2 01-21-2006 03:50 PM
