Unread 01-24-2023, 12:07 PM   #1
Andrew O
Firebox
Hi,
First time poster. I'm tiling my brick fireplace. I'm using a ledger board to support the row of tiles above the firebox (12" square zellige mosaic). My question is, when is it safe to remove the ledger board? How long until the thinset is sufficiently set that the tile isn't in danger of falling off or sagging?
thanks,
Andrew
Andrew
Andrew O is offline   Reply With Quote
Unread 01-24-2023, 12:39 PM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Overnight is plenty in most cases.
Peter
Unread 01-25-2023, 03:23 PM   #3
Hi Andrew, Welcome aboard.
Unread 01-26-2023, 12:42 PM   #4
Andrew O
update and grout question
Thanks! It's coming along nicely.
Trying to attach a picture. Not sure I did that right but we'll see.
Wondering if anyone has advice on grout. The lines are paper thin, less than 1/16". Will regular un-sanded grout work on this? I'd use a portland cement based grout because it's on a fireplace.
Most grout lists 1/16th as the minimum size, but I'd rather not leave this ungrouted if possible.
Andrew
Unread 01-26-2023, 12:58 PM   #5
Definitely use an unsanded grout, Andrew.
Metal Firebox mark942 Tile Forum/Advice Board 3 03-23-2013 03:08 PM
Firebox Paint mk636 Tile Forum/Advice Board 5 04-28-2009 07:07 PM
Tile around firebox Looking4ideas Tile Forum/Advice Board 2 12-28-2007 06:34 PM
1st timer: slate over cbu over drywall and firebox shaunflanders Tile Forum/Advice Board 3 04-01-2007 05:28 PM
Masonary firebox JohnF Professionals' Hangout 17 10-11-2002 07:01 AM
