Unread 02-01-2023, 05:20 PM   #16
makethatkerdistick
John, I used the manual expander tool because I only had two joints I had to complete, one to the water meter coupler in my front yard, and another that connects the PEX A to my copper main trunk line inside my house.
I chose 1 1/4 in PEX for the main line, and boy was it tough to expand manually, including the rotation of the tool. This is necessary to avoid uneven grooves inside the pipe while expanding and thus prevents leaks (which your Milwaukee tool does automatically). You can get away with the manual tool for a few fittings, but if you do an entire house, the electric tool is really necessary.
Wolfgang
Unread 02-02-2023, 12:50 AM   #17
You'll improve your hand strength (after you recover!) if you use a hand expander regularly...power is much nicer (and faster).
Unread 02-02-2023, 09:06 AM   #18
PC7060
PC7060's Avatar
I still use copper but switched over to a Ridgid ProPress system several years ago. Sometimes only hard pipe will do. I’ve attached a copy images of a 3/4” copper heat trap I recently added to an Indirect DHW system.
If I do another large project I’ll probably switch over to Uponor Pex system and get a battery expander like the OP.
PC7060 is online now   Reply With Quote
Unread 02-02-2023, 09:20 AM   #19
That's pretty, PC, but what do it do?
Unread 02-02-2023, 09:47 AM   #20
PC7060
PC7060's Avatar
The trap won’t allow the hot water to passively circulate, gets caught at the top of the loop and the cold get trapped at bottom as shown in the thermal image with the hot water coming from the right shown in red and to colder water (blue) settling out on the left side.
The previous configuration DHW line was passively circulating over a 9’ section ending where a 5’ horizontal run of pipe went up over an obstruction and then dropped back down. The hot water would rise up the pipe and along the horizontal section until it hit the section where the pipe dropped. As the hot water cooled it fell to the bottom of the horizontal section (same pipe) where it would flow back to the tank creating oversized trap that allowed a continuous circulation.
Normally hot water tanks have check valves to prevent this. I could have added a check valve instead of the heat trap but given I had the pipe and fittings on hand I went with the trap.
Unread 02-09-2023, 12:22 PM   #21
mullet
mullet's Avatar
All I use is type K copper, I use a chopsaw for cuts a wheel cutter takes forever.
chuck
my first Kerdi Shower
Unread 02-09-2023, 12:28 PM   #22
PC7060
PC7060's Avatar
Agree, I use the Milwaukee 12v cutter. It's a wonder!
I see the price has gone up (like everything else).
https://www.supplyhouse.com/Milwauke...BoCKWQQAvD_BwE
Unread 02-17-2023, 07:14 AM   #23
bottlefed
bottlefed's Avatar
Great timing on this thread,
I have dozens of M-18 tools but don't do enough showers to justify purchasing the expander.....particularly since they added 100 dollars to the price for the new style expansion heads.
However I have been slow over the winter and decided to do the master bath remodel in my house and that led me to replace all the old cast iron and galvanized. Then after going that far, I decided to replace all the 66 yr old copper as well.....so I broke down and got the tool.
I have to say the tool is the most impressive thing I have purchased since my first Fein tool.....Can't wait to get a chance to get started on the PEX!
Richard
bottlefed is offline   Reply With Quote
Soldering Copper Pipe oakview The Mud Box 13 04-01-2012 11:01 PM
Sealing 1/2" copper pipe seatofpantstile Tile Forum/Advice Board 7 01-19-2012 10:39 AM
how to bend copper pipe lati_cz The Mud Box 17 03-14-2011 04:13 PM
copper pipe and cement jerseyjoe Tile Forum/Advice Board 12 01-30-2005 10:29 AM
Epoxy on Copper Pipe cx The Mud Box 22 03-08-2003 09:23 AM
