SLC manufacturers require lath on a wood subfloor. Check the specs about minimum thickness above the highest point. With the electric heating wires, you might want to consider the plastic lath verses metal. I think the metal will be okay only if you don't walk on the stuff before you get it covered with the slc. Metal lath has sharp edges, and you could damage the wires if you walked on them. Safer to use the plastic lath. The combination of the lath and wires will mean you should plan on making sure you cover the wires at the high point deep enough. Don't remember the thickness above the heating elements that is recommended - you might want to check the specs on the stuff you are planning to use.
