Unread 06-26-2022, 10:22 PM   #1
Kevinjm4
Penny grout problems
Mapei ultracolor plus FA warm grey. Porcelain Penny rounds.
I could go into detail with the install method I used. Let’s just say I’m a beginner and I’m sure I didn’t execute as well as a pro would. I tried following instructions best I could, but was not easy. I did as good of a job as I could have hoped as this was my second ever tile job and first floor I’ve done. I followed mixing instructions consistently for all three bags. The application instructions I intended to follow but once things were going, I had a harder time. So there’s a chance the discoloration is from my inexperience and inconsistency in my install. Any relevant questions about just ask... (Basically I grouted the joints, squeegeed over, then waited. Once it didn’t transfer to finger I tooled the joints to my liking with a rung out sponge, tried to keep sponge clean as I went, then swiped once with each side of sponge then rinsed and rung, and repeat. Wait til dry then buffed with white 3m scotchbrite pad.)
At any rate, is there a remedy to this? I grouted Saturday early evening if that’s relevant. The tiles look fine and feel clean, but the grout is splotchy, and inconsistent. I tried a spot clean with denatured alcohol and there was no change. I washed the entire floor in 6:1 water to vinegar and mopped with clean water and no change after that dried.
Side question, when the grout gets wet it gets darker, is that normal and will this always be the case? I didn’t grow up around tiled bathrooms/kitchens, I didn’t ever do tile work, I really just don’t know..
Thanks for the help!
Kevinjm4 is offline   Reply With Quote
Unread 06-27-2022, 08:13 AM   #2
Lazarus
Lazarus's Avatar
Likely there was too much water used for the clean up.
Yes, it will typically darken when wet...temporarily. Often, you can darken the grout with the application of an "enhancing" sealer. Home Depot sells it...
Laz...
“Always listen to experts. They'll tell you what can't be done, and why. Then do it.”
Unread 06-27-2022, 04:21 PM   #3
You might try using a grout stain although I have no idea how easy it will clean off the tiles. It might be worth trying.
Penny Round Grout Cracking...and My Sanity FishFL99 Tile Forum/Advice Board 16 02-13-2022 02:37 PM
Penny Round Grout Problem Tazotoo Tile Forum/Advice Board 2 09-06-2018 07:08 AM
Penny flooring using real penny? JoeBoxer Tile Forum/Advice Board 1 01-16-2014 09:18 AM
Penny problems-- GC dispute Zeitgast Tile Forum/Advice Board 25 12-10-2013 08:42 PM
penny tile -- grout questions Sue_D Tile Forum/Advice Board 4 04-18-2009 07:46 AM
