Unread 04-21-2022, 09:28 PM   #1
JEANMARCB
travertine grout and backer rod use
Hi,
Trying to grout new travertine coping around our pool. the travertine is 12x12x1. grout lines are approx 1/4 to 3/8 wide.
Can i use backer rod to fill 1/2 the height of the grout line and then grout over it instead of filling the full 1" heigth of the travertine ?
I know backer rod is used with caulk, but what could prevent it from beeing used with grout ?
Thanks for any help.
Jean
JEANMARCB is offline   Reply With Quote
Unread 04-22-2022, 12:10 PM   #2
Hi Jean,
I would grout it solid. Backer rod is definitely for something that's flexible.
Unread 04-22-2022, 12:20 PM   #3
Note that the grout helps stabilize the whole tile installation and especially the edges to help prevent a heavy load from cracking an edge, so having the joint full is desired.
Unread 04-22-2022, 03:11 PM   #4
jerrymlr1
jerrymlr1's Avatar
Hi Jean. You are talking about grouting between the coping pieces alone? The joint between the coping and whatever is on the adjoining deck needs flexible sealant. There you could use the backer rod. Like John and Jim have said tho, the coping stone needs full grout. Why are you looking to do it like this?
Jerry
Unread 04-23-2022, 10:42 AM   #5
JEANMARCB
@ Jerry
My question was in reference to the grout between the tiles; i know the side that touches the deck needs a flex sealant.
Since the tile is 1" thick, i was thinking about putting a backer rod on the bottom an grout about 1/2" tall. That is what i will do on the deck side where the sealant will be on top.
So I was just wondering if there was a drawback to doing it this way on the grout sides also, instead of filling the entire 1" height.
Jean
Enhancer Pro Sealer - Travertine - To grout or not to grout. DeviantMagick Cleaning, Restoration and Sealing 5 12-01-2009 10:30 AM
Travertine Shower, 1/8" Grout Lines. Best Grout? funk Tile Forum/Advice Board 16 06-17-2009 09:20 PM
Backer Board over Vinyl /Epoxy Grout AnnePDX Tile Forum/Advice Board 1 08-07-2007 10:37 AM
thickness of backer board for travertine vicshayne@yahoo.com Tile Forum/Advice Board 4 09-24-2004 05:50 PM
Tumbled Travertine Backsplash backer question Geeper Tile Forum/Advice Board 3 09-02-2004 09:47 PM
