Unread 02-13-2022, 10:05 AM   #1
SouthLouisiana
Kerdi Board
I am doing a complete bathroom renovation and considering using kerdi board on my shower walls. My shower will be larger at 9’x5’ than the original which was 3’x5’ and is located in the corner of my house. The house is a brick veneer with foam insulation under the brick attached to the studs. The old shower was cultured marble over hardi. It is my understanding that the hardi possible acted as structural sheathing to help strengthen the walls. My question is, by using the kerdi board will I reduce the structural integrity considering it is foam?
SouthLouisiana is offline   Reply With Quote
Unread 02-14-2022, 10:21 AM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
I doubt the HardieBacker was installed with any structural intent. It would certainly be a first for me and not what Hardie specifies for their product.
The exterior sheathing or diagonal brace of some kind would be providing shear strength at corner of house.
That's a huge shower. I'd be more concerned about hot water capacity and temperature, but then I like steamy, hot showers.
Peter
Unread 02-14-2022, 08:01 PM   #3
makethatkerdistick
By foam under the brick do you mean a continuous layer of foam sheathing on top of the wall sheathing, thus maintaining an air gap between brick veneer and wall system? Or are you saying that spray foam has been injected in that space, potentially reducing drying ability of said space?
Wolfgang
Unread 02-15-2022, 06:37 PM   #4
SouthLouisiana
Carbidetooth, I do see diagonal bracing, there is no sheathing except for the 4’x8’ foam board between the studs and the brick. As for the hot water I agree we have a 11gpm tankless water heater. The shower theoretically could use up to 30gpm but will never happen because the the line coming into the house won’t supply. That’s another project for another time. We needed the bathroom first.
Thanks for your help on the hardi question.
Makethatkerdistick, there is 4’x8’ foam sheets about 3/4” thick attached to the studs then air gap then brick.
John
Unread 02-15-2022, 08:39 PM   #5
makethatkerdistick
That is great. Must be new construction. It goes a long way in reducing thermal bridging.
Wolfgang
Kerdi Board or Laticrete Hydro Ban Board Availability Igman Tile Forum/Advice Board 10 12-24-2021 02:57 AM
Kerdi Board Hydroban Board questions Igman Tile Forum/Advice Board 4 03-10-2021 03:47 PM
Wall Tile Backer Board: Hardie, DensShield, Kerdi Board and others: Thoughts? machinemanjr Tile Forum/Advice Board 14 04-21-2017 04:40 PM
Green board? Cement board? Kerdi board? cburrows84 Tile Forum/Advice Board 7 03-21-2014 11:44 AM
Kerdi Board - Cement Board - Gypsum? PaulEdmonton Tile Forum/Advice Board 7 03-03-2013 07:35 AM
