In searching through the HardieBacker FACTS, they say the maximum stud spacing is 16" OC, so you'd need to install some additional studs, which may be the best thing rather than cladding it with plywood then the board to keep the thickness down.
You might get by installing some cleats on the sides of the studs and install the plywood so it was flush with the stud edges, and you could probably use 3/4" stuff, and then the HardieBacker, but it still probably wouldn't be an approved installation.
